Car shakes upon acceleration and downshifts..
Old Apr 15, 2005 | 12:08 AM
[626]95-GSR's Avatar
Default Car shakes upon acceleration and downshifts..
I recently (4 months ago) had my clutch changed.. I went with an Exedy Organic.. While the shop was changing the clutch, they also said i needed new axles. So, i went ahead and got some axles from them too.
After everything was installed, i broke the clutch in for the first 1000 miles. After that period, i started to get on the gas a little more. I noticed that the car would shake at lower rpms upon acceleration. From 2-4300rpm the car would shake some, but after that point it would smooth out. It does it in pretty much every gear as long as im in that RPM range.
Forward to today when the shaking has seemed to gotten worse all of the sudden. Now it shakes not only when i accelerate, but when i downshift too. As the clutch engages it starts to shake, and shakes as it slows down. The shaking as i accelerate has gotten more violent. I also tried to kind of "launch" the car and it shook really violently, mad wheel hop.. Please help me out.. i need this fixed by this weekend.. thanks guys
Old Apr 15, 2005 | 12:19 AM
Neighborhood Superstar's Avatar
Default Re: Car shakes upon acceleration and downshifts.. ([626]95-GSR)
most likely its your axle. did you get a reman. one from like autozone or so? sometimes those could be defective as well.
when you driving and you throw it in neutral, the vibration stops right?
in my case, 1st you really couldnt notice, but once you get it in 2nd and start to accelerate, the vibrations start to occur. usually 2nd and 3rd gear is when it shakes violently.
Old Apr 15, 2005 | 01:13 AM
Default Re: Car shakes upon acceleration and downshifts.. (=Gameover=)
The axles i got i believe were reman... I never saw them since I had the clutch replaced at Autolink. So i was unsure of the brand. Your symptoms are pretty much the same as mine.
Old Apr 15, 2005 | 01:32 AM
''s Avatar
motor mounts?
Old Apr 15, 2005 | 01:40 AM
Default Re: (L337HXR)
ill have to check those this weekend.. but im sure they arent too bad..
Old Apr 15, 2005 | 02:58 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: ([626]95-GSR)
could be a wheel bearing? i also second the axles. my cv boot leaked grease and it eventually had the same problems as you're describing. when cruising it feels smooth and fine, but when accelerating it feels like a very strong pulsation.
Old Apr 15, 2005 | 03:06 AM
civiccpedx's Avatar
Default Re: (AzntaggeR)
take it back to the shop that put it in, and see whats up
Old Apr 15, 2005 | 06:27 AM
TriniTech's Avatar
Default Re: (civiccpedx)
i agree take it back and let them look at it, i think motor mounts too.
Old Apr 15, 2005 | 08:17 AM
panix's Avatar
i had that problem and took it to the shop. They replaced my axels with better more expensive ones. no idea wat brand sry. but since then there hasnt been any jerking
Old Apr 15, 2005 | 08:26 PM
Default Re: Car shakes upon acceleration and downshifts.. (panix)
so all signs point to axles? chances of both of them going bad?
Old Apr 16, 2005 | 08:33 AM
panix's Avatar
well no. that was just my problem and since they have been replaced there hasnt been any sounds. but that doesnt mean its ur problem. it could be a number ov things...
OhBai
Jan 21, 2012 06:58 PM
[626]95-GSR
Apr 16, 2005 11:15 AM
nikker
Aug 25, 2004 07:38 AM
Blaze45
14
Jul 28, 2003 08:26 PM
tooqwik1
Jul 14, 2002 03:26 AM
