Tire size problem on 93 Hatch
Ok im hoping I can get some help tonight seeing as im going to go buy some tires tomorrow. I am putting tires on some LS mesh wheels, I tryed them on my car tonight with the current tires and they rub in the back they are 205/50/15s .........I know people run this size on H/Bs and I havent heard any one say they rub. Do you roll the inner fender lip or what? since they rub proably going with 195/55/15. Im sure part of it is that my car is droped but I just havent heard any one say 205s rubbed bad
heres my hatch:
BTW right now rolling on some 185/60/14s
heres my hatch:
no frame isnt tweaked for one the car is mint and 2 it would rub on one side and not the other. I will try to lift the car some I guess, I have H&R coilovers but the spaner wrench is long gone
any thing else work good to adjust coilovers with ?
i run 195/55/15 on my fat fives
doesnt rub at all but i have like 1inch wheel gap
dont forget to take your car to an alignment shop
since you are raising your car and new rims
205 / 50 / 15
width/height/size of rim
195/55/15 would be a thinner, taller tire. If you like your ride highth, try a 195/50/15 tire, thats what i ran on my 95 gsr teg with a 2-2.25 drop on h&r's, and thats whats on my hatch right now. Thats my$.02, hope it helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssbpturbohatch »</TD></TR><TR><TD CLASS="quote"> 205 / 50 / 15
No, it goes width/aspect ratio/size of wheel... its not like 50 mms or something it goes with the width of the tire..
</TD></TR></TABLE>No, it goes width/aspect ratio/size of wheel... its not like 50 mms or something it goes with the width of the tire..
As a one-time tire salesman, allow me to educate you all:
205/55 YR16 is an example of a tire size and speed threshold designation.
205 is the tread width in mm.
The 55 is the percent of 205mm the sidewall subtends (55% of 205mm = 112.75mm).
Y is the speed designation, Y being the highest non-race designation I've ever seen.
R16 tells you that it fits a rim with diameter 16 inches.
You could have set the camber in -1 to -2 and been alright.
I have huge *** azenis on my civic. Largest they make in 16. At 0 camber the rear rubbed big time. At -1.5 they don't rub at all. Of course I don't roll as low as the rest of you.
jay_cue
11
Dec 28, 2006 12:46 PM
