Easy fuel rail question
Old Apr 14, 2005 | 08:55 PM
tianporn's Avatar
Default Easy fuel rail question
Hey i have a couple of questions.
1. Does an ITR fuel rail fit straight onto a JDM B16a?
2. How do i go about swapping the fuel rail? As far as i know you just undo all the bolts holding the rail on and undo the banjo bolt on the left hand side. Does it just come straight off the injectors?
3. Also where is the valve where you release the pressure of your fuel system?
Help needed. Thanks
Old Apr 14, 2005 | 09:03 PM
Kendall's Avatar
Default Re: Easy fuel rail question (tianporn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn &raquo;</TD></TR><TR><TD CLASS="quote">Also where is the valve where you release the pressure of your fuel system?</TD></TR></TABLE>
What valve?
Old Apr 15, 2005 | 05:07 AM
tianporn's Avatar
Default Re: Easy fuel rail question (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
What valve?</TD></TR></TABLE>
Well how do i relieve the pressure off my fuel rail? You're not very helpful are you? Ok so theres no valve, MY BAD. So can you be more helpful and actually tell me how to do it?
Old Apr 15, 2005 | 06:30 AM
TriniTech's Avatar
three 10mm nuts at the top of the rail hold it to the intake manifold, be careful when you remove it, the injectors coem off with it, dont lose the o-rings that hold them in place.
Old Apr 15, 2005 | 06:56 PM
tianporn's Avatar
Default Re: Easy fuel rail question (TriniTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TriniTech &raquo;</TD></TR><TR><TD CLASS="quote">three 10mm nuts at the top of the rail hold it to the intake manifold, be careful when you remove it, the injectors coem off with it, dont lose the o-rings that hold them in place.</TD></TR></TABLE>
Will fuel **** out when i do this though?
ballerchild
10
Mar 17, 2007 11:16 PM
rewerbcrx
Oct 19, 2005 08:31 AM
SiShane
Jun 8, 2004 02:56 PM
dohced
Feb 25, 2004 07:43 PM
