A little CRX clutch funny business?
Old Apr 14, 2005 | 08:47 PM
madhatter07's Avatar
Default A little CRX clutch funny business?
Hey guys,
On my way back from the FSAE shop tonight I was in fifth gear rolling up to a stop light. I put in the clutch and went to slide it into fourth but it wouldnt go, into any gear even. So I stopped at the stop light and it was really hard to force to shifter into gear, like it took a good amount of pressure and revving it to get it in there. Then when I would try ot leave the light it would just die on me. So i put it into nuetral and when I would release the clutch it would just die. I eventually slipped it into third and it would start rollingforward a little and then after that i slipped it in first and it was fine. The clutch engaged really high after that though and I know you can adjust it but I am curious as to what might have caused this so it's something I can fix. Thanks a lot for any input you guys have. My only guess is that it might have gotten stuck in fifth but i dont know what that would happen, shift linkage maybe? As far as the car goes its a stock D16A6 with a stock clutch. The shifter is a dc sports shot shift kit with poly busings. Thanks guys,
Matt
Old Apr 15, 2005 | 06:02 AM
Default Re: A little CRX clutch funny business? (madhatter07)
anyone?
Old Apr 15, 2005 | 09:49 AM
bump
Old Apr 15, 2005 | 03:09 PM
bagpipe goatee's Avatar
sounds like a clutch or tranny problem. this sort of thing happened with my friends tranny, turned out a gear broke off his final drive and jammed it up in there. you weren't beating on the car beforehand, were you?
Old Apr 16, 2005 | 03:07 PM
Default Re: (bagpipe goatee)
no i was cruising in fifth at about 55 mph. I would be very dissapointed if it was a trans problem lol
Old Apr 17, 2005 | 10:13 AM
Default Re: (madhatter07)
bump
Old Apr 17, 2005 | 12:20 PM
when that happened to us we were in the same gear, same speed, but about 2 hours before we were trying to see how fast we could get the car. little did we know the tranny had a slight leak and it was low on oil... try draining your tranny and seeing if its got 2 quarts of oil in it like its supposed to.
Old Apr 17, 2005 | 12:29 PM
hmm thta would suck , i will have to do that though, i was planning on putting some GM syncromesh in it anyway, now it shifts fine but it is a bit noiser which could be explained byu the low tranny fluid. thanks guys
Old Apr 17, 2005 | 03:47 PM
Burlyirishdude's Avatar
change the oil.....I had the same problem... You need about 2.2quarts in your tranny....I use GM synchromesh.....just b/c everone said too....to take care of it.
civicexkid1
18
Jun 28, 2012 10:52 AM
93delslow315
Feb 5, 2010 07:08 AM
slowdaintegra
Dec 21, 2005 01:31 PM
CaTiRo
16
Feb 14, 2004 08:18 PM
FR-MOB: ThE bEe GuY
Oct 19, 2002 10:11 PM
