Si tranny on a Gsr
a b16 transmission would be a perfect upgrade from the gsr. Since it has shorter gears, you will be at a higher rpm approximately 4200 instead of 3900 in 5th gear at cruising speeds (80 mph). If money is not an issue, I would atleast look into an itr transmission because it has the LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deep »</TD></TR><TR><TD CLASS="quote">Yeah, deff go with B16, same specs as U.S. Type R trannies without the LSD. </TD></TR></TABLE>
don't forget the final too.
u will definately feel a difference in acceleration. If you decide to get a B16 tranny make sure u try and get an LSD on there before u put it on and it'll be cheaper than getting an ITR tranny. It'll save u time/money if u plan on doing that later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freshazzburu »</TD></TR><TR><TD CLASS="quote">
u will definately feel a difference in acceleration. If you decide to get a B16 tranny make sure u try and get an LSD on there before u put it on and it'll be cheaper than getting an ITR tranny. It'll save u time/money if u plan on doing that later. </TD></TR></TABLE>
yeah, well he'll have the 4.40 R version, a 4.785 final drive would deff be a great upgrade...
REDEM1FTW
Transmission & Drivetrain
Aug 6, 2010 12:50 PM
IT'S ME DAVID
May 29, 2007 05:36 PM
