I washed my motor and my car is runing bad
I have a b16a I think water got in to my distributor. I covered it with a shirt when i washed it and it did not look wet after washing it. The car actully ran fine for a couple of hours. Now it feels like it is running on onley 2 cylinders off and on mustly when i try to gas it it stumbles.. It has been like this for 3 days now. Iwas hopeing it would dry out on its own and be ok. What do you guy think.
pull your spark plug wires....probably have a ton of water in there causing a missfire....just take air and blow water out....you should be good to go!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">probably have a ton of water in there causing a missfire....</TD></TR></TABLE>
that happened to me before.
I doubt it would be that, but its worth a try. I would check out all the connectors to make sure there dry but its possible you friend a module by getting it wet, good luck...........
that happened to me 2 i have a b16a ...take off the spark plug wires there will probably be water in there....and if not remove the distributer cap and dry it ...when that happened to me i was like damn its over for my motor but now its back 2 normal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote"> I did take off the cap and the was no water in there i also puled a couple spark plug wires and there was no water. Thanks for the sugestions though.</TD></TR></TABLE>
YOU DIDN"T TAKE THEM ALL OFF????
it is possible to get water in only 1 of them!!!!
You guys were right there was so much water i the #1 sparkplug wire area. Took care of it today and it is running fine now. Thanks agin. I feel kinda stuipid that i didn't pull all the plug wires in the first place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote"> You guys were right there was so much water i the #1 sparkplug wire area. Took care of it today and it is running fine now. Thanks agin. I feel kinda stuipid that i didn't pull all the plug wires in the first place.
sweet deal!!!!!!!!!
i guess i do know what i'm talking about....that is not directed to you katoeh2o...but to all the idiots that talk crap!!
</TD></TR></TABLE>sweet deal!!!!!!!!!
steadfastCRX
Nov 7, 2005 08:42 AM
polishprinze
Oct 30, 2005 02:25 PM
