So whats a good tool to make straight and accurate cuts ?
Old Apr 14, 2005 | 05:55 PM
RCautoworks's Avatar
Default So whats a good tool to make straight and accurate cuts ?
Is a chop saw good enough ? Not looking to make cuts accurate to the tenth. Just need something better then an angle grinder with a cut off disc attached.
http://www.harborfreight.com/c...47003
Or would this be better
http://www.harborfreight.com/c...37151
People if you have these products, feel free to comment on them please
Old Apr 15, 2005 | 10:00 AM
ManBearPig4silly's Avatar
The HF chop saw is bunk. I hate mine and never use except to chop random huge *** pieces of angle when the occassion calls for it. I have a Dake 7x12 bandsaw so I cant really comment on the HF one. Of course either one of your options will make a more acurate cut than a grinder with a cut off wheel.
Old Apr 15, 2005 | 12:19 PM
2KWK4U's Avatar
I have a Craftsman Professional series 14" chop saw, and I really like it.
Old Apr 15, 2005 | 12:49 PM
CRXDrew's Avatar
I have a Makita shop saw. I love the thing. Originally bought to help my sister cut lumber to renovate her house. Now it has a metal abrasive disk and is doing its automotive duties.
Old Apr 15, 2005 | 11:22 PM
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">I have a Makita shop saw. I love the thing. Originally bought to help my sister cut lumber to renovate her house. Now it has a metal abrasive disk and is doing its automotive duties.</TD></TR></TABLE>
Around how much did you pay for it ?
Old Apr 15, 2005 | 11:43 PM
ExploitedRacing-HR's Avatar
I think they both suck. I owned that bandsaw and it sucked ***... i use the larger bandsaw they sell and it works great. been using it for about 2 years and use it every day.
Old Apr 16, 2005 | 09:36 AM
SpeedDreamz.com's Avatar
Default Re: (ExploitedRacing)
I have that hf band saw and have to say that it sucks ***.. I went back to my chop saw. To start cuts I use a half worn out blade that way you dont have as much walk.
Old Apr 17, 2005 | 09:17 PM
GForceInteg's Avatar
Default Re: (SpeedDreamz.com)
HOLY HELL!!! I thought the drop saws where more than that. Ima go pick one up tomorrow. thanks oh yeah get the drop band saw, the chop saw will throw sparks and just a pain in the @22.
whats wrong with that drop saw? which one would you guys suggest in its place. ive used the drop saws and the chop saws are a huge pain.
Old Apr 18, 2005 | 11:57 AM
Default Re: (GForceInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg &raquo;</TD></TR><TR><TD CLASS="quote">HOLY HELL!!! I thought the drop saws where more than that. Ima go pick one up tomorrow. thanks oh yeah get the drop band saw, the chop saw will throw sparks and just a pain in the @22.
whats wrong with that drop saw? which one would you guys suggest in its place. ive used the drop saws and the chop saws are a huge pain.</TD></TR></TABLE>
I'm hearing good things from about the band saw. Hopefully the guy that is telling me the good things will post in here.
Also if you have not bought it yet,. sign up at harbor freight for the email service, and they will send you a 10% off coupon
Old Apr 18, 2005 | 04:50 PM
Default Re: (90blackcrx)
Anyone else ?
Old Apr 18, 2005 | 05:18 PM
90DALS's Avatar
i have the 14" HF chop saw, i use it on all my manifolds, it does fine. i got it for 49.99 tho (instead of 99.99). i have a HF retail store 10minutes from my house
Old Apr 18, 2005 | 05:41 PM
Default Re: (90DALS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90DALS &raquo;</TD></TR><TR><TD CLASS="quote">i have the 14" HF chop saw, i use it on all my manifolds, it does fine. i got it for 49.99 tho (instead of 99.99). i have a HF retail store 10minutes from my house </TD></TR></TABLE>
Nice, I am really looking at the bandsaw now. Just need more opinions on it.
Old Apr 18, 2005 | 06:05 PM
McCann Racing's Avatar
I have used and abused that green band saw 90blackcrx has pictured for about 8-10 years. I use it to cut large stock, drop the blade and walk away. The cuts are not acurate -- towards the end of the cut the blade has a mind of its own. I have tried adjustments, different blades, loosen and tighten blade, but nothing has worked.
I use it accasonally (sp), not as much as I intended. By far, I use a sawzall for rough cuts, and finish with a 4" grider.
Good for -- 3" and larger c channel, 3" and larger pipe and tubing, axles...
Bad for -- any plating, right angle stock, roll bar tubing (much easier w/sawzall), sheet metal
I worked at a machine shop years back where they had a BIG drop band saw ($2000 or more) that cut acurately...you will not receive these results for $100.
Old Apr 18, 2005 | 06:30 PM
Motorhead_AZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else ?</TD></TR></TABLE>
I have that HF band saw and it works pretty well, atleast for what I use it. It's definately worth the money. The cuts look very clean all the way to the end. Unlike what a few people said, there is no distortion or side-to-side blade movement as it makes the cut. As I said, cuts come out very streight.
The only thing I don't like about it is the stand. They could have made it beefier. It's fine when the saw is cutting, but when you move it, it starts to wobble and flex. You can bolt a few pieces of angled iron to it and fix the rigidity problem.
I bought mine for 159.99 plus tax at the local HF store. I recommend it to all
Old Apr 18, 2005 | 08:34 PM
kb58's Avatar
Banned
Default Re: (Motorhead_AZ)
I'm another supporter of the HF bandsaw. Yeah the stand sucks but it gets the job done; after I got it I never used my chopsaw again. Say what you will, but it built the car in my sig so no complaints from me. Is it as good as a $2000 drop saw? No. Is it good enough for someone's garage shop? It was for me. I never had trouble with the cuts wondering. I use the best quality blades I can find and the only issue I have is when I jam the blade. The blade will stop but the wheels keep turning, and the blade will jump off track. So what... it works fine for me and I've gotten more then my money's worth from it. No if everyone who hates the little saw wants to pool their money and buy the guy the $2000 version, I'm sure he'll appreciate it!
Old Apr 18, 2005 | 09:39 PM
Default Re: (kb58)
Thanks guys, gonna end up getting the bandsaw
Old Apr 19, 2005 | 11:09 AM
mopar junkie's Avatar
i have the HF band saw and the $40 ebay chop saw. The band saw wins hands down. With a new blade it cuts very straight. The only problem I have with it is the blades wear out very fast. If I bought some high quality blades it would probably last longer....
Old Apr 20, 2005 | 06:32 AM
AspectIndustries's Avatar
Default Re: (mopar junkie)
Any suggestions of what type of high quality blades should I look for? For steel cutting.
( Is this band saw recommended at all to create collectors etc? )
Thanks.
Old Apr 20, 2005 | 07:20 AM
JustChou's Avatar
Default Re: So whats a good tool to make straight and accurate cuts ? (90blackcrx)
I HATE that green bandsaw. I too have tried everything to get it to cut well, but it's just horrid. It cuts straight...but not perpendicular to the floor! Save yourself the frustration.
Old Apr 20, 2005 | 08:02 AM
92HB_HB's Avatar
Default Re: So whats a good tool to make straight and accurate cuts ? (JustChou)
the $49 HF chop saw is pretty good for the money.. I"ve used it to cut all of my metal .. i'm still on my 1st disc too..
Old Apr 20, 2005 | 08:49 AM
Default Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions of what type of high quality blades should I look for? For steel cutting.
Thanks. </TD></TR></TABLE>
http://www.kimini.com/
It built his car he said, so I would think it could handle collectors
89ED
Oct 28, 2011 08:42 PM
JDubya
Welding / Fabrication
14
Jun 5, 2008 08:21 AM
Briang3a3
Jan 13, 2008 12:14 AM
diyer
Mar 12, 2006 01:34 PM
jdmotorsports
12
Oct 11, 2005 06:05 PM
