head swap
Old Jan 29, 2002 | 07:26 PM
maximedx's Avatar
Default head swap
do you think to put this head on my d15b2 block. because i really like to convert sohc to dohc.
88-91Si16-1.6i
88-91CRX Si16-1.6i
(Asian specs)
90-93 Integra LS
90-93 Integra RS ZC
D16A8/A9 1595cc
4 cyl, 16 valve
DOHC
9.6:1 c.r.
PGM-FI (MPFI)
137 bhp @ 6800
Redline: 7200 rpm 108 lb-ft @ 5700
Old Jan 29, 2002 | 07:27 PM
Mugen Dom's Avatar
Default Re: head swap (maximedx)
no aint happening buy a zc if u want a cheap dohc
Old Jan 29, 2002 | 07:29 PM
EP3_05's Avatar
I don't think the dohc zc head will fit on the d15b2 block without a ton of machine and custom fabrication work. Why not just swap in the entire zc?? Just a thought.
Old Jan 29, 2002 | 07:33 PM
maximedx's Avatar
Default Re: head swap (91civic)
i dont like swap engine because i don't like to change all my motor mount.it's really tof job
Old Jan 29, 2002 | 07:34 PM
Mugen Dom's Avatar
well then ur stuck with wut u got
Old Jan 29, 2002 | 07:36 PM
EP3_05's Avatar
the zc swap does not require the changing of any motor mounts. You can use your stock ones.
psyphre's Avatar
I'm no Civic/CRX expert, but what i've learned from the accords is there is no way you can put a dohc head on a sohc block. Well, anything is possible but i'd be hella cheaper to just swap the whole motor.
Old Jan 29, 2002 | 07:39 PM
maximedx's Avatar
Default Re: head swap (psyphre)
ok so if i buy a 90 integra rs motor they fit exactly in my car with no modification.it's bolt on
Old Jan 29, 2002 | 07:41 PM
Mugen Dom's Avatar
the 90 teg has a b18 not a zc the zc is only in japan and is a d series motor
Old Jan 29, 2002 | 07:42 PM
EP3_05's Avatar
Buy the black valve cover zc if you want a bolt in swap to an 88-91 civic/crx.
Old Jan 30, 2002 | 04:54 AM
keithv's Avatar
i think the 86-89 teg motor bolts right in. i could be wrong....
Old Jan 30, 2002 | 05:08 AM
virginia_dude's Avatar
Default Re: head swap (breaka_1_9)
The Older TEG motor is a Olive color 1st Gen ZC and has only 113 Hp, Get the Black Cover ZC it has 130-133 depending on souces. Bolts right in, if you have a HF or SI the wiring fits too. DX is a biit more of a bitch. I am in the middle of a 2g ZC into a '89 DX hatch. Wiring is on workbench ready to be modified. Bolts right up to the stock 5-speed, stock mounts fit too. I had clearance problems with the A/C compresssor but nothing a sledge hammer can't fix. Stay away from the older TEG motor not enough power to be worth the work.
Old Jan 30, 2002 | 11:24 AM
CimorelliCRX's Avatar
Default Re: head swap (virginia_dude)
DX wiring isnt too difficult man. My only problem was getting a pin in at B15, but once I got that in my car was set. I love my ZC in my DX. Wish I woulda had money to get the SI tranny at the time.. Thats my next thing, a SI tranny.
Old Jan 30, 2002 | 11:50 AM
Hondasaurs's Avatar
For the most part a new head will cost you as much as a used DOHC ZC. I'm cracked my head in my D16 so i then bought a ZC. It was cheaper and I did the install with a friend helping me in about 10 hours.
Old Jan 30, 2002 | 12:12 PM
Default Re: head swap (CimorelliCRX)
A question? I picked up what I was told were resister packs from a local yard, it has 4 black wires and one red one if I remember right. Does this sound right to you. This is a really stupid question once you have ever seen one but I haven't. I have one that is like a big heat sink from an Integra, and a dumb looking one from a Civic SI, which inside the metal can has a ceramic block with the same color wires as the other one coming out of it. THis is my first honda and my first Non-american engine swap. Car was a non runner when I aquired it.
Old Jan 30, 2002 | 12:41 PM
CRzex's Avatar
New User
are you talkin about an injector resistor box? If you are and you have a dx that is one of the parts you need to convert it from dpfi to MPFI. Im not sure about the wire colors but it looks kinda like what u are describing. Some one correct me if im wrong.
[Modified by CRzex, 1:41 PM 1/30/2002]
B18C1_CRX
Jul 10, 2006 12:09 AM
claysold
Sep 21, 2005 04:47 PM
HondaHemi
Sep 4, 2005 11:12 PM
Hulkbuster
Feb 8, 2003 11:08 AM
