Torque specs????
Old Apr 14, 2005 | 03:50 PM
one pnt 6 hatch's Avatar
Default Torque specs????
does anyone know torque specs for arp head studs in a b16a???
Old Apr 25, 2005 | 06:03 PM
WannabeEF9's Avatar
Default Re: Torque specs???? (one pnt 6 hatch)
70 lbs with arp moly assembly lubrica t, or 85lbs with 30wt motor oil. right off arp instructions
Old Apr 25, 2005 | 07:35 PM
.1type.'s Avatar
10lb. for the stud use assembly lub, then first 30lb on the nut, and then 70lb...
Old Apr 25, 2005 | 08:48 PM
rjay8604's Avatar
Default Re: Torque specs???? (1type)
My ARP sheet recommended 65 ft. lbs. because of the expansion rate of aluminum. I used that. But it also says 70 ft. lbs before that, but since the head is aluminum i went ahead and opted for the aluminum recommendation. ?
slo_b18
Jan 30, 2008 08:47 AM
TokuiAutowerks
Oct 12, 2005 09:11 AM
bluebomb
Jul 13, 2004 03:04 PM
bodydropranger
Feb 3, 2003 03:10 PM
NorCalHB
Dec 1, 2002 10:37 PM
