GSR Tranny not going into gear?
Old Apr 14, 2005 | 03:49 PM
B18CJDM ITR's Avatar
Default GSR Tranny not going into gear?
I just got done putting my motor and tranny all back into my car and i went to start it.....strarted up fine and then i went to drive it but the car will not go into gear. I bled the clutch a good 10 times or more, the slave is working good the fork moves but the clutch is not engauging. While the car is running with the clutch in it will not go into gear...i know the cluch is not engauged. Its like trying to put in into gear with the clutch out, doesnt work. Before i take my tranny off anyone have any advise? Thanks
Old Apr 14, 2005 | 05:28 PM
turbo_b16_ex's Avatar
maybe the throwout bearing isnt on right, oil in the tranny needs to move around a little bit. do you have pressure on the clutch?
Old Apr 14, 2005 | 06:18 PM
Default Re: (turbo_b16_ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">maybe the throwout bearing isnt on right, oil in the tranny needs to move around a little bit. do you have pressure on the clutch?</TD></TR></TABLE>
i think its the throw out my self also....oil is in the tranny, and there is a good pedal thats what i dont really get....but i guess the tranny is just gona have to come off
Old Apr 14, 2005 | 06:36 PM
eyeamvic's Avatar
I had it happen after I did my swap. Somehow the clutch bolts came loose. Wish I had used loctite. I had to drop the tranny to find my problem.
Old Apr 14, 2005 | 07:30 PM
vtec y0's Avatar
Default Re: (eyeamvic)
guess u have to do more work.
Old Apr 15, 2005 | 10:05 AM
well b4 u take off tranny pull the boot off a bit and get a flashlight and look in there, see if everything looks right. u said u put a new clutch in, correct?
Old Apr 16, 2005 | 05:56 AM
i took the boot off and looked in there and everything seems good.....im did a bunch of stuff to it and then went to start the car and now i gota go get a battery oh well ill let ya know what happens
Old Apr 16, 2005 | 06:33 AM
moto1320's Avatar
Default Re: (B18CJDM GSR)
did you put the friction disk in upside down?
Old Apr 16, 2005 | 06:40 AM
Default Re: (moto1320)
thats what i thought at first also...but i took all my stock stuff and put it together outside the car, and the pp will not go onto the flywheel with disc the wrong way and i call ACT and they said that its the same thing it will not bolt up. but thanks for the looks.....
Old Apr 16, 2005 | 10:20 AM
moto1320's Avatar
yes it will...ask me how I know. Embarassing as it is I will admit it. It was probably about the hundredth clutch job I did when this happened too, just got in a hurry. A better question to ask would be does the tranny shift normally when the car is not running. How does the clutch pedal feel?
Old Apr 16, 2005 | 10:49 AM
jdmcx's Avatar
i think you need to adjust the peddle height
ps when the car is off you can put it into gear without a problem??
if you put it in gear and then start the car what happens??(be care full do this with nothing infront of you if car starts to move press on clutch pedel)
what if you start the car and push the pedel down half way and then try to put it in gear?
just somethings you could try
Jason
Old Apr 16, 2005 | 08:22 PM
Default Re: (jdmcx)
If i have the clutch pedal in with the car on, it doesnt go into gear but the car seems to want to go foward....and then i go to put it into gear with the car off it goes no goes in no problem......i just wana drive my car lol
globy123
Jun 20, 2008 10:54 AM
Manolo
18
May 18, 2005 09:21 AM
chemical
Feb 10, 2005 09:35 AM
Ditdogs
Apr 4, 2004 07:44 PM
Synergy001
17
Dec 8, 2003 10:07 PM
