S2s3 valvetrain question
Old Apr 14, 2005 | 03:02 PM
MI4$DC5's Avatar
Default S2s3 valvetrain question
16 type r outer valve springs, 16 portflow stiffened inner valve springs, and 16 omni titanium retainers.
Will they be strong enough to hold some sKunk stage 3s?
Old Apr 14, 2005 | 03:51 PM
.H22 POWER.'s Avatar
Default Re: S2s3 valvetrain question (MI4DC2)
Im not sure about the valve springs. omni retainers and portflow springs should hod up fine though.
Make sure you tune!
Old Apr 14, 2005 | 08:23 PM
UncleD's Avatar
Default Re: S2s3 valvetrain question (.H22 POWER.)
I would say it depends on what you plan on revvin that too. If you're going past 8,500, which I hope you are to realize the potential of those camshafts, I would drop the itr/portflows and do Rm gen 1's. The gen 2's would work also, but with a camshaft that has 12.8 lift you want the stiffest you can get. The RM valvetrain is the best that money can buy IMO.
Old Apr 15, 2005 | 12:38 PM
MI4$DC5's Avatar
Default Re: S2s3 valvetrain question (clean rice)
thanks, i just wanted to know cause i had a good deal lined up on them, i think ill just stick to the blox bs. thanks guys
Old Apr 15, 2005 | 09:48 PM
pr0honda's Avatar
skunk2 stage 3's have alot of lift and duration so i would say do not use that combination get some good springs... spend the money right the first time in this area.. broken valve would destroy your engine so you want to have the correct parts..
my opinion is if you are running anything bigger than say crower stage 2's dont use the oem out spring and portflow inner. this combination works great for ctr cams and slightly larger cams.
skunk2 stage 3's are one of the bigger cams on the market.
Old Apr 16, 2005 | 12:08 AM
UncleD's Avatar
Default Re: S2s3 valvetrain question (pr0honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0honda &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 stage 3's have alot of duration</TD></TR></TABLE>
Actually, they have very little duration......just allot of lift. And compared to some of the camshafts that are available now, they are fairly small compared to a BC5 or RM M24E.......
Old Apr 16, 2005 | 12:17 AM
pr0honda's Avatar
well i guess i know nothing.....
by no means are the skunk2 s3 small.... by the way what are the duration numbers of the skunk2 s3? and show me how they are fairly small...
of the camshafts you listed which have you ran?
Old Apr 16, 2005 | 08:57 PM
pr0honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, they have very little duration......just allot of lift. And compared to some of the camshafts that are available now, they are fairly small compared to a BC5 or RM M24E.......</TD></TR></TABLE>
lets discuss cams clean rice...
skunk2 stage 3's at 050 i get 260 duration intake ex. 269
rocket m24e i at 050 i get 258 duration intake ex. 258
buddy club 4's at 050 i get 257 duration intake ex. 259
i have not seen the buddy club 5's yet. but seems like you have. what do you get at 050 on the bc5's??
and what were you saying about the skunk2's having no duration?
shawn
Old Apr 19, 2005 | 11:25 AM
DavidT or VajT's Avatar
shawn
Old Apr 19, 2005 | 11:31 AM
Supernatural's Avatar
Default Re: S2s3 valvetrain question (DavidT or VajT)
portflow springs and retainers on stage 3 skunks is what i use
Old Apr 19, 2005 | 12:32 PM
pr0honda's Avatar
Default Re: S2s3 valvetrain question (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">portflow springs and retainers on stage 3 skunks is what i use</TD></TR></TABLE>
there is nothing wrong with portflow springs.. he is asking about using oem outer and portflow inner which is not a good idea. if you get the portflow inner and outer it should be fine.
isnt it funny when someone trys to correct you on something they have no idea about........
Old Apr 19, 2005 | 01:25 PM
AllMotorMadness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI4DC2 &raquo;</TD></TR><TR><TD CLASS="quote">16 type r outer valve springs, 16 portflow stiffened inner valve springs.</TD></TR></TABLE>
I use the same combo with my sk2 stg.3 cams no problems here.....
Old Apr 19, 2005 | 01:26 PM
mini-cRx's Avatar
i am doing gsr with pro 1 what can i use also thats good but cheaper for springs and retainers and valves this is a good thread
Old Apr 19, 2005 | 03:05 PM
isnt it funny when someone trys to correct you on something they have no idea about........</TD></TR></TABLE>
port flow vavle springs are oem type r outers and there own custom inners....now if your talking about regular b16 or gsr outers then no......
longfellahh
Mar 8, 2006 05:36 PM
Sideshow9090
Feb 3, 2005 10:00 AM
6ghatch
Aug 18, 2004 05:15 PM
B18Redline
Feb 16, 2004 07:36 AM
