dizzy trouble
i was converting my b16 from obd0 -> obd1 today, and the firsth thing i started with was to change the distrbutor, and after that did i plug the p28 ecu to the conversion harnes and the old wiring.i did not hook up the o2 sensor.
but when i tried to start it did it sound like it only was running on 3 cylinders, (un burned gas in the exhaust)
so i shut i down right away and checed the wiering to the dizzy, and installed a set of new plugs.
and now it is just dead! wont start at all. when i m checking for sparks is it just the on one of the plug wires, and a second one comes on somtimes...
what can the problem be?? how can i messure ifd its ok??
found out one problem. the coupling between the dizzy and the cam was broken. so thats why it did not rotate... so now im getting sparks. but the car wont start
well, i have matched the colours one distributor harnes right. so that should be ok. but when i messured the dizzy yesterday. was i not able to messure resistance between the terminal A and C. but between A and B was it fine..
can i just use an external MSD coil and bypass the internal?
but i do get spark on all the wires!!! aint that strange that it wont start. it smels fuel on the spark plug
Modified by CRXnorway at 4:38 PM 5/18/2005
Harrymonk
Nov 29, 2018 03:31 AM
FTNW
Dec 7, 2010 01:10 PM
andrew714
Dec 13, 2007 09:35 PM
