Questions about the greddy e-manage on a Type SH
Old Apr 14, 2005 | 11:13 AM
Don Jefe's Avatar
Default Questions about the greddy e-manage on a Type SH
Hey guys
Im considering going to with an e-manage over a vafc, but i have a few questions.
1. Will the e-manage wipe out my ATTS?
2. Since my car is OBD2, will i be able to tune for partial throttle as well as Full throttle?
(as opposed to vafc only tuning WOT on obd2 cars)
3. To be more general, is it a good unit? Does it preform well?
4. Ive heard you cant re-adjust the vtec engagement point, is this true?
I think thats about it guys, thanks for any help you can give me.
Old Apr 14, 2005 | 01:41 PM
2kflamedlude's Avatar
Default Re: Questions about the greddy e-manage on a Type SH (Hank the retard)
I will not wipe out your atts and for what you have and if you want little more tuning abilities the emanage is good.. I am running one and my car is SS auto tranny and thats why i chose to go with for my supercharger..
Old Apr 14, 2005 | 01:43 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hank the retard &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys
I think thats about it guys, thanks for any help you can give me.</TD></TR></TABLE>
you'll keep your ATTS
you can't tune partial throttle
it is a good unit, people have been getting decent results
you can fully adjust VTEC engagement
and you can roughly tune ignition timing.
Old Apr 14, 2005 | 01:58 PM
sharkcohen's Avatar
Default Re: Questions about the greddy e-manage on a Type SH (bad-monkey)
Not being able to tune part throttle has nothing to do with your ECU being OBDII. OBDI also has Short Term Fuel Trim and Long Term Fuel Trim, you would run into the same troubles.
You wouldn't want to mess with part throttle closed loop anyway, the stock ECU does an excellent job of taking care of that..
Old Apr 14, 2005 | 06:13 PM
Don Jefe's Avatar
Default Re: Questions about the greddy e-manage on a Type SH (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Not being able to tune part throttle has nothing to do with your ECU being OBDII. OBDI also has Short Term Fuel Trim and Long Term Fuel Trim, you would run into the same troubles.
You wouldn't want to mess with part throttle closed loop anyway, the stock ECU does an excellent job of taking care of that..</TD></TR></TABLE>
Okay, with that said, will none of my tuning affect any throttle below 100% (WOT)? Am i understanding you correctly?
Thanks for all of your help.
Old Apr 14, 2005 | 10:46 PM
TimeRacer's Avatar
E-manage is a glorified V-AFC if you're trying to tune it for a mild N/A build. Basically its a V-AFC + guesstimation on timing if you get that harness. Overall I wouldn't recommend it for a mild build, if you're going to do cams and build the engine it becomes more worthwhile.
Old Apr 15, 2005 | 08:12 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hank the retard &raquo;</TD></TR><TR><TD CLASS="quote">Okay, with that said, will none of my tuning affect any throttle below 100% (WOT)? Am i understanding you correctly?
Thanks for all of your help.</TD></TR></TABLE>
Well, let me add to what I said. It's not that you cannot tune part throttle, it's that you cannot make changes in areas where the ECU runs in closed loop. My understanding is that the ECU goes into open loop fueling at about 35% throttle.
Old Apr 15, 2005 | 06:17 PM
Don Jefe's Avatar
Default Re: Questions about the greddy e-manage on a Type SH (TimeRacer)
Ohh, i gotcha, thanks shark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">E-manage is a glorified V-AFC if you're trying to tune it for a mild N/A build. Basically its a V-AFC + guesstimation on timing if you get that harness. Overall I wouldn't recommend it for a mild build, if you're going to do cams and build the engine it becomes more worthwhile. </TD></TR></TABLE>
I'm deciding between this and a vafc because im going to be purchasing a Rage header soon, and from what ive heard, it leans out your car a fair amount.
Anyone else care to reply?
Thanks in advance guys
Old Apr 16, 2005 | 12:18 AM
TimeRacer's Avatar
I HIGHLY doubt that the header by itself leans out your fuel system more than the stock ECU can compensate for. If that's what you're worried about, don't bother with it. But the E-manage is actually good for adding fuel, just crap (V-AFC equiv) in taking it away.
jdm j
Honda S2000
21
Aug 7, 2007 01:13 PM
kingofkingz
May 15, 2005 08:52 PM
itr1244
Jun 15, 2004 01:04 PM
civicr97
Jul 23, 2003 10:43 AM
