motor swap blues :(
UPDATE the car is running now. only 1 problem. on the passenger side shock tower there are 4 plugs. the smallest one [that has 3 wires coming out] i have no idea where it goes. the wires were cut by a friend of a friend
this is a 98 b18c1 using obd1 p72 in a 93 dx
ok so we got the obd2a b18c1 into a 93 dx hb.
final steps to complete the swap.
*repin passenger stock tower harness (for some stupid reason im keeping the car obd2)
i need help/tips/advice for the above.
*connect shift linkage
*connect rear mount "L" bracket
*plumbing
Modified by superpho at 11:06 AM 9/18/2005
*plumbing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpho »</TD></TR><TR><TD CLASS="quote">
*plumbing
Can you be any more specific as to what you need? For the wiring, just find a pinout diagram and trace the wires. PITA, but you'll know it's right.
*plumbing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpho »</TD></TR><TR><TD CLASS="quote">ok so we got the obd2a b18c1 into a 93 dx hb.
Just plug the OBD2 B18C harness into your Civic's shock tower plugs. Done.
Then just add the vtec, ks, & iab wires to your ecu plugs.
Find an OBD1 P72 to use with your B18C and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpho »</TD></TR><TR><TD CLASS="quote">can't i just plug the motor harness into the civic harness and run the obd1 to obd2a and call it a day?</TD></TR></TABLE>
yes, if you have an obd1 ecu that's exactly what you need to do. Like boomslang said, just run wires for vtec, ks, and iab. And to make it really easy...
Vtec solenoid - A4
Vtec pressure switch - D6
Vtec pressure switch ground - A26
Knock Sensor - D3
IAB - A17
Good luck man.
Vtec solenoid - A4
Knock Sensor - D3
IAB - A17
Good luck man.
i guess ima obd1 it then. thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
Vtec solenoid - A4
Knock Sensor - D3
IAB - A17
Good luck man.
Vtec solenoid - A4
Knock Sensor - D3
IAB - A17
Good luck man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpho »</TD></TR><TR><TD CLASS="quote">ok so i wired most the wires, but another problem came up. o2 sensor. i have a 4 wire o2 sensor..is that plug and play?</TD></TR></TABLE>
4 wire is correct for obd1.
hatchback032
Sep 4, 2013 09:32 AM
NWP4LIFE
Feb 17, 2005 09:57 PM
Se-rv-Tak
Nov 29, 2003 11:59 AM
