ALB Light on JDM EF8 cluster. *SEARCHED!*
Old Apr 14, 2005 | 10:18 AM
ef8 h0!'s Avatar
Default ALB Light on JDM EF8 cluster. *SEARCHED!*
I SEARCHED AND CAME UP WITH PRETTY MUCH NOTHING, THE OTHER TREADS SAID ANTI LOCK BRAKE, DONT THINK THAT'S WHAT IT IS........i have no idea what this light coming on is. its not a cel, its a light on the bottom right of the gauge cluster. reads with yellow backround "ALB". i called password and they said it would probably be a sensor thats not on a USDM car. but if that was true wouldn't it be on all the time? it only comes on when the engine is under a load. any help would be much appreciated.
Old Apr 14, 2005 | 10:22 AM
ef8 h0!'s Avatar
Default Re: ALB Light on JDM EF8 cluster. *SEARCHED!* (ef8 h0!)
no one?
Old Apr 14, 2005 | 10:26 AM
messeduprex's Avatar
in japan some crx's came with Anti Lock Brakes thats why The ALB light is there
Old Apr 14, 2005 | 10:27 AM
ef8 h0!'s Avatar
Default Re: ALB Light on JDM EF8 cluster. *SEARCHED!* (messeduprex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">in japan some crx's came with Anti Lock Brakes thats why The ALB light is there</TD></TR></TABLE>
thats what i thought too. but wouldent it be on all the time then? why does it only come on sometimeS?
Old Apr 14, 2005 | 10:29 AM
no because you dont have the wiring for anti lock brakes so its not reading it
Old Apr 14, 2005 | 10:30 AM
ef8 h0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">no because you dont have the wiring for anti lock brakes so its not reading anything and the light has no power</TD></TR></TABLE>
no it flickers on and off.
Old Apr 14, 2005 | 10:31 AM
do you have a motor swap? if so are you using a jdm b16 ecu?
Old May 12, 2005 | 09:25 PM
escoperkett's Avatar
you know how to swap a jdm ef cluster into 89 si?
Old May 12, 2005 | 10:08 PM
stmizner's Avatar
Default Re: ALB Light on JDM EF8 cluster. *SEARCHED!* (ef9escohatch)
i'm having the same issue but with the overheating light. flickers on and off. sometimes off for a minute at a time, sometimes on when the car starts and no real reason why so far. bump to solve for both us.
Old May 13, 2005 | 06:42 AM
JohnnieChimpo's Avatar
Default Re: ALB Light on JDM EF8 cluster. *SEARCHED!* (stmizner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 h0! &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i thought too. but wouldent it be on all the time then? why does it only come on sometimeS?</TD></TR></TABLE>
US CRXs never had ABS or EF8 clusters. Someone had to rewire your cluster plugs to make the EF8 cluster fit since it doesn't just plug in. A US CRX has 2 plugs on the cluster (HF has 1 for shift light too) and the EF8 has 3 plus one for the little car in the bottom right.
No one except the guy who wired your cluster will know why your light is coming on.
Who ever rewired your cluster plugs must have wired the ALB wire to something else. Open your cluster hood and trace the wires that feed the ALB light and tell us what colors they are.
I was thinking of wiring mine to my Vtec so I could see it come on and the Cat light to the two stage manifold.
adobospoon
Feb 25, 2009 10:47 AM
superslow-oto
13
Sep 4, 2008 06:22 AM
brainglow
Mar 1, 2007 09:47 AM
TomTomTuning
Honda S2000
Sep 10, 2006 02:39 PM
.jacob
Jan 31, 2003 07:35 AM
