WHich camber kit For 99 SI
I need to buy a REAR camber kit for my EM1 since the inner part of the tires is started to give out (H&R Race Springs) , but i dont know which one to buy. does any of u guys with EM1 use a camber kit on the rear? if so, which brand and where do u get it ( great deal preferred )
Thanks for the response guys!
You get better adjustablitly with adjustable arms, but they are a little pricey. You could also do the rear shim kit. Look in the FAQ thread up top. There is a thread about the shim trick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">grade 8 bolts and washers man.</TD></TR></TABLE>
agree with this...however... i had a H&R race setup on my teg and the washer trick didnt work since the car sat so low. camber still gonna be there, need to get a kit.
^^ They are right. The washer trick will not correct enough camber. Only .75 degrees safely. Also, stay away from no name/generic kits. As you can see, this is an important part of your suspension. $105 with free shipping will get you an Ingalls kit which is one of the highest quality kits around. Ingalls has specialized in camber kits for over 25 years! Email me if you have any further questions. We are one of the largest camber kit dealers in the country.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 »</TD></TR><TR><TD CLASS="quote">srr rear camber kit
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
those are absolute junk. the bushings just plain suck. nothing beats the tried and true ingalls rear kits with poly bushings.
cheap and next to no wear.
</TD></TR></TABLE>those are absolute junk. the bushings just plain suck. nothing beats the tried and true ingalls rear kits with poly bushings.
Jdmbryan
Suspension & Brakes
11
Jun 14, 2012 03:59 PM
drewbie
13
Jan 6, 2005 03:13 PM
confucius
Dec 12, 2001 09:50 PM
