Apexi gt manifold
Primaries: 45mm
Secondaries: 50.8mm
Collector: 60.5mm
Its designed to give a compromise between the standard 4-2-1 design and a 4-1 design as its primaries are considerably longer than most 4-2-1 headers. Gains are also supposed to be very good with it. The pipe size is the same as many JDM headers eg: Fujitsubo, HKS, 5zigen, Mugen etc etc if you can ge it cheap then go for it.
Secondaries: 50.8mm
Collector: 60.5mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnEG6 »</TD></TR><TR><TD CLASS="quote">the only modding i would havta to do is to get a different cat correct?</TD></TR></TABLE>
if u get 2.38" size u can use stock one. but if u get 2.5" bolt will not match up with stock cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 »</TD></TR><TR><TD CLASS="quote">
if u get 2.38" size u can use stock one. but if u get 2.5" bolt will not match up with stock cat. </TD></TR></TABLE>
They only make on size...2.38" (60.5mm)
SpoolnEG6..yeah why not if its a good price
riceforlife
Dec 10, 2007 02:34 PM
riceforlife
Nov 24, 2007 09:57 PM
bright rider
Mar 10, 2007 03:29 PM
slayersluck
Dec 31, 2004 04:02 AM
