what are these numbers stand for?
Old Apr 14, 2005 | 04:33 AM
GsR-Freak's Avatar
Default what are these numbers stand for?
i was checking tires for my 15" and not too familiar with sizing of tires and their numbers stand...so take it easy on me instead of bs and leave negative feedbacks
205-50-15
205(?) - 50(?) - 15(rim 15" right?)
what's each individual number stands for?
thanks all
Old Apr 14, 2005 | 04:41 AM
..::91TEG-G2::..'s Avatar
Default Re: what are these numbers stand for? (GsR-Freak)
205 = width of tire/tread. stock is 195
50 = sidewall higth. stock i believe is 55 for DC's
15 = yes you're correct, the rim size. and 15 is stock for DC's
Old Apr 14, 2005 | 04:42 AM
95lstegman's Avatar
205: this is the "tread width." 205mm. not the width at the widest part of the tire, the tread width.
50: this is the "section" or "profile." 50%. this is the distance from the bead to the tread, and is 50% of the tread width. in this case, that would be 102.5mm. this counts part of the tire that's actually inside the rim, so you may not measure a full 102.5mm (almost exactly 4") from rim to tread of the tire when the tire is installed on a rim.
15: you guessed it, "wheel size." self-exlpanatory.
overall, 205/50-15's are a great size for factory 15" wheels. enjoy!
gsrdEK
Aug 5, 2007 06:20 AM
kupras
Aug 25, 2005 06:38 PM
808State
Jan 30, 2005 12:48 AM
combustion
Nov 6, 2003 07:21 AM
Toda
Apr 27, 2002 11:11 PM
