Around 240-245 with compression tester!press the gas pedal all the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 555R »</TD></TR><TR><TD CLASS="quote">well in my motor it pegs 300 psi jun 3s with JE 12.5s
i need to figure out how to get a gauge that reads higher</TD></TR></TABLE>
Go to McMaster.com and order an Ashcroft gauge that reads 400 psi.
Can I go off topic just a tad here? How many of you guys actually check your comp. warm? I've allways been scared to do it becaue I am afraid of stripping out the sparkplug holes. You are supposed to take em out of a cold engine.
how many miles have you guys driven your cars before you did a compression test? i should have around 12:1, and had crower stage 2's while doing a compression test, at around 300-400 miles on my motor...the guage read 250 across...just wondering if it'll be higher now since i've driven for about 200-300 more miles.
okie i'm having the same thing.. What i'm looking for is a 11:5:1 somewhere around there..and i get a reading of .. 235-250 is that a gooD sign or no.. and this is on a Ls Block/ Gsr head, srp 10:1, deck & head has been resurfaced.. ?? is this right or wrong.. adn i'm using the crower stage2 cams..
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsRxtreme »</TD></TR><TR><TD CLASS="quote">okie i'm having the same thing.. What i'm looking for is a 11:5:1 somewhere around there..and i get a reading of .. 235-250 is that a gooD sign or no.. and this is on a Ls Block/ Gsr head, srp 10:1, deck & head has been resurfaced.. ?? is this right or wrong.. adn i'm using the crower stage2 cams.. </TD></TR></TABLE>
what the hell r u talking about if your pistons are 10:1 how do u come up w/ 11:5
230ish is normal for the 10.1 compression motors
as for me
well it always pegs 300 psi after 2-3 pumps so i know its a 12.5 slightly higher since the head was shaved 10 thou
the number isnt important its that they are even across the board
if they are within i think 5 % YOU ARE FINE
ITS WHEN YOU TEST AND YOU GET 3 AT 240 AND 1 AND 200
THEN THERE IS A PROBLEM BEGINNING TO SHOW
as for me
P@@RB@Y
Nov 16, 2005 12:39 PM
dohcter g
17
Mar 23, 2005 07:47 PM
