cryo treating the crank and cams?
Old Apr 14, 2005 | 01:24 AM
Green Lude 93's Avatar
Default cryo treating the crank and cams?
i am currently building my engine to handle higher boost. i am wondering if it is wise to cryo treat the crank. i got a quote to do it for only $80. reason why i am asking is because i dont know if it is suppose to expand in heat or not for the rod bearings to work properly. and i dont know if cryo treating it would affect the expansion of the metal in heat. i am also considering doing the cams also. i have the crower stage 2 turbo cams. i am skeptical on this because i know you have to do valve adjustments when the engine is cold so i know parts of the engine works more efficent with heat. Also does cryo treating affect the metal's original size? if it shrinks or expands from its original size.
Old Apr 14, 2005 | 01:25 AM
btw... i did do a search and i didnt find the info i wanted to know.
Old Apr 14, 2005 | 04:48 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Green Lude 93)
I'm not sure what cryo treating does to crank journals... Might be a great idea for the rods.
Old Apr 14, 2005 | 02:57 PM
Default Re: (LSVTEC 91 Civic)
yes. i did think of that do but the same question remains if it alters the actual physical shape or not and does it affect expansion of metal in heat.
Old Apr 14, 2005 | 03:04 PM
Archidictus's Avatar
Unceasing Measure
Get the crank micropolished and the rods cryo-treated. That's all you'll need and even that much might be overkill.
Old Apr 14, 2005 | 03:36 PM
Default Re: (Archidictus)
thanks
Old Apr 14, 2005 | 04:15 PM
notstock93's Avatar
Not to hijack this thread, but has anyone cryo-treated a set of piston rings?
I was going to do it (its dirt cheap) but I couldn't get an answer from anyone as to whether it would alter the ring break-in in any way. Thoughts?
Ekcoupe1818
May 11, 2019 11:08 AM
Devo94ac
Apr 11, 2006 07:24 PM
miahmouse
Apr 14, 2004 11:09 AM
wignersfriend
Sep 3, 2002 04:29 AM
