Where To Get Tools...Valve Guide Seal Remover/Timing Light
Old Apr 13, 2005 | 09:05 PM
Slomies's Avatar
Default Where To Get Tools...Valve Guide Seal Remover/Timing Light
Once again I need a few more tools. This time it is a valve guide seal remover and a timing light. I need the vgsr to replace the valve seals on my f22 head. I went to autozone and got the valve spring compressor tool, but they didnt have the valve guide seal remover and I forgot to ask about a timing light. does anyone know where i could get these tools? I really want to get my car up and running in the next week or so. Modified Madness is only 5 weeks away and I hope to be ready to go by then...
Old Apr 14, 2005 | 12:31 AM
Intense3.2's Avatar
Default Re: Where To Get Tools...Valve Guide Seal Remover/Timing Light (95AccordVtec)
try sears
Old Apr 14, 2005 | 03:49 AM
notoriousB's Avatar
Default Re: Where To Get Tools...Valve Guide Seal Remover/Timing Light (Intense2.2)
^^ good idea
autozone has timing lights
summitracing.com has all sorts of engine building tools available.
Old Apr 14, 2005 | 04:14 PM
matt_in_sd's Avatar
Have you pulled the head to replace the seals? If not is the valve spring compressor you got meant to be used with the head on or off? When I did my seals I had to find a tool truck to get the kind of compressor that lets you replace the seals with the head still on. As for removing the seals I just used a pair of vice grips to carefully pry the seals off.
Old Apr 15, 2005 | 09:16 AM
Slomies's Avatar
Yes I pulled the head off because I had a blown head gasket. The spring compressor tool that I have I didnt need to pull the head off, but it was already off. I'll try to use a pair of vice grips to carefully pry the seals off...
boomersz
Feb 26, 2007 07:41 PM
ricearoni56
16
Jun 19, 2004 09:16 PM
biggie2005
Feb 26, 2004 06:23 PM
Muckman
Jun 19, 2003 07:42 AM
civicracer1993
Apr 6, 2003 01:01 PM
