1" Master Cylinder into a CRX, what parts needed?
I've done some searching but I can't seem to find a clear answer. I think that a 00 GSR master cylinder and booster will bolt in but i'm not positive about that. I dont want to go buy some parts to find they dont fit. Oh and BTW for those who think it's overkill I plan on upgrading to eather NSX front calipers (if I can find some) or Legand front calipers in the near future (got a set of 15s for free so I can fit some bigger brakes under there)
BTW I know that I need to bend the stock lines or make new lines to go into the MC so I know it's not a complete bolt on affair
And for teh pics ppl, 1" MC in a CRX, i just dont know how they did it
Yes you can use the GSR/ITR MC/BB but like you mentioned you need to bend the lines.
You can also use the DA integra w/ ABS master cylinder.
Or if you don't need that much MC you can use the EF sedan EX one (15/16).
Good luck
Good luck
Check with 4drEF or Eggman, I believe they are the ones that make that MC brace that is in the pic so they might know some info on that.
It fits with no problems. All you need to do is slightly bend the lines to line up.
That was for a 1" MC/Booster from a '98 type R, I don't know if they're all the same or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Check with 4drEF or Eggman, I believe they are the ones that make that MC brace that is in the pic so they might know some info on that.
That looks like a quality piece
</TD></TR></TABLE>That looks like a quality piece
adrian1281
Aug 23, 2003 09:43 PM
That makes sense.
