5th Gen Prelude Front bumper material?
Old Apr 13, 2005 | 07:43 PM
Unlimitationz's Avatar
Default 5th Gen Prelude Front bumper material?
What material is used in Honda's genuine front bumpers?
I am worried because I am about to buy a bumper from this guy, he said the bumper is urethane. Now I don't know if thats a good thing or bad thing.
Which material is good and which is not good? Help.
Old Apr 13, 2005 | 07:52 PM
The Phil's Avatar
Default Re: 5th Gen Prelude Front bumper material? (AznUnlimitationz)
Urethane.
Good = Urethane. Stock bumpers are made out of this. When hit, it deforms and may crack under high stress.
Bad = Fiberglass. Ricershit bodykits are made from this. When hit, it explodes in a fine mist of fiberglass and rice.
Old Apr 13, 2005 | 08:13 PM
Default Re: 5th Gen Prelude Front bumper material? (xthephilx)
HAHAH. Thank bro.
Old Apr 13, 2005 | 10:22 PM
Lude454's Avatar
one bad thing about urothan is that paint does not stick to it as well so don't use a presure washer on it
Old Apr 14, 2005 | 06:26 AM
madcowdk's Avatar
If you make sure that it is primed and sealed correctly before it's painted then you won't have any problems with the paint.
Old Apr 14, 2005 | 10:59 AM
MeUglyDuckie's Avatar
Default Re: 5th Gen Prelude Front bumper material? (madcowdk)
i thought the bumper was made out of abs or was that just the oem kit?
Old Apr 14, 2005 | 11:01 AM
SiRLudeVtec's Avatar
When installing the front bumper, do you use the same mounting hardware....or do you buy new ones?
Old Apr 14, 2005 | 11:03 AM
The Phil's Avatar
Default Re: 5th Gen Prelude Front bumper material? (Lude454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude454 &raquo;</TD></TR><TR><TD CLASS="quote">one bad thing about urothan is that paint does not stick to it as well so don't use a presure washer on it</TD></TR></TABLE>
OEM bumpers are urethane. The paint doesn't explode if you pressure wash it. Proof that if you paint it right it'll stick.
Old Apr 14, 2005 | 11:07 AM
So, if hit - fiberglass explodes? hmm...didn't know that....does it look the same while on a car - is it noticeable that it's fiberglass?
Old Apr 14, 2005 | 11:36 AM
The Phil's Avatar
Default Re: (SiRLudeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRLudeVtec &raquo;</TD></TR><TR><TD CLASS="quote">So, if hit - fiberglass explodes? hmm...didn't know that....does it look the same while on a car - is it noticeable that it's fiberglass?</TD></TR></TABLE>
Yes, fiberglass is highly explosive. Be careful around it. A friend of mine had his finger blown off by it once.
You can tell a fiberglass kit on a car because usually they're cheaply made and are lumpy.
Old Apr 14, 2005 | 11:53 AM
98TypeSH's Avatar
Default Re: (xthephilx)
fiberglass doesnt flex well. Its very brittle and will crack and if hit with enough force will explode into fine plastic like peices.
Urethane flexs. If hit it will flex to an extent then crack and break. not explode and shatter like **** fiberglass would. you gets what you pay for.
Old Apr 14, 2005 | 12:22 PM
madcowdk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
OEM bumpers are urethane. The paint doesn't explode if you pressure wash it. Proof that if you paint it right it'll stick.</TD></TR></TABLE>
Old Apr 14, 2005 | 01:06 PM
silver97prelude's Avatar
Fiberglass is for speaker boxes, not bumpers.
Finest
Paint and Body
May 21, 2007 01:34 PM
Shingo
Jul 29, 2005 02:56 PM
B18ls*RAYON
Jan 17, 2005 12:04 AM
kin6david
Feb 1, 2004 01:37 AM
