What is this part?
Old Jan 29, 2002 | 05:18 PM
InfamousRS's Avatar
Default What is this part?
It came with the Energy Suspension Shift Stabilizer kit. The kit did not come with instructions so I do not know???
Could this be where it goes?
Anyone have a know?
Old Jan 29, 2002 | 05:24 PM
AssPenny's Avatar
Default Re: What is this part? (BLK94RS)
The stabilizer bar that bolts to the motor. You'll see it.
Old Jan 29, 2002 | 05:30 PM
InfamousRS's Avatar
Default Re: What is this part? (AssPenny)
That leads to the motor??? Is it shift related? What does it do?
Old Jan 29, 2002 | 06:29 PM
Rain_man's Avatar
New User
The shifter linkage is made up of two rods. One rod runs from the motor (or tranny, I forget) to the hub that the shifter sits in. The other rod runs parallel to the first rod and runs from the shift rod you have pictured to the tranny and is the one that actually changes gears.
The bushing you have goes on the first rod that I was talking about, which is just held on by a bolt. Take off the bolt and then using a screw driver pry off the old bushing. Then use some grease on the new bushing and pop it on. It's a bitch and you'll want your car on jack stands for some space to work with.
Old Jan 29, 2002 | 06:33 PM
Erik_Pb_Foot's Avatar
New User
Default Re: What is this part? (Ein)
That bushing was a snao to put on for me.... but I also, like you, thought it went on the shifter... I pressed it OVER the ball of my first short throw shifter, tried to put it in... and when i reached for the socket, i sawwhere it was supposed to go... i was PISSSSSED... I had to press it back out over the ball again, talk about a pain.
I wish I had a camera, I used the forklift at my work as a press... lowered the forks on the bushing.
LOL
Old Jan 29, 2002 | 07:53 PM
SonicGSR's Avatar
Default Re: What is this part? (Pb_Foot)
Damn thats funny!
Old Jan 29, 2002 | 07:56 PM
New User
Default Re: What is this part? (SonicGSR)
It wasn't funny to me.... at the time....
Damn i wish I had a camera.
It would ALMOST be worth re-enacting.
Old Jan 29, 2002 | 08:01 PM
vteg's Avatar
New User
With a forklift, who needs jack stands?
Old Jan 29, 2002 | 08:13 PM
InfamousRS's Avatar
Default Re: What is this part? (vteg)
Will I notice a difference in anything with that bushing instaled? What does it have to do with shifting if it connects to the motor? I think Im a little lost.
Old Jan 29, 2002 | 08:23 PM
alexboy's Avatar
rubber goes in the part of the shift linkcage that is located right below the shifter on the underside
Old Jan 29, 2002 | 08:25 PM
boosted1993fd's Avatar
The rod connects from your shifter.........to the tranny to shift the gears ...the bushing probably just takes some of the "play" out of the shifter when you move it around.
Old Jan 29, 2002 | 08:35 PM
New User
Default Re: What is this part? (Interlude)
if you can jack the front of your car up and put it on jack stands, with a socket wrench it will take you 10 mins at most... you've got the bushing... might as well use it. it can only help.
Old Jan 29, 2002 | 08:45 PM
InfamousRS's Avatar
GOOD!!!! I hate the play in my shift lever. Im definatly going to put it on.
minitruckskunk
Transmission & Drivetrain
Jul 6, 2017 07:57 PM
hondazccivic
Aug 4, 2008 06:11 PM
1sikhatch
Apr 24, 2007 11:48 AM
mymeatb18"
Oct 30, 2005 10:35 PM
NitrousB.I.G.
Nov 21, 2004 04:18 PM
