Just installed my camber kit, but it doesn't WORK.
Old Jan 29, 2002 | 05:06 PM
fcuked's Avatar
Default Just installed my camber kit, but it doesn't WORK.
well my car is a 92 hatch dx. it's lowered almost 4 inches, so i installed the ingalls front camber kit and i can only have it on the smallest setting which gets rid of very little camber and i can't max it all out to to it's 3 degree setting. That's because when i do, the upper control arm hits the freaking fender and the car just rests on the upper control arm. Does anybody know how to fix this?
btw i did do a search but couldn't find anything with this exact same problem and its solution.
Old Jan 29, 2002 | 05:45 PM
Jared's Avatar
Default Re: Just installed my camber kit, but it doesn't WORK. (1.8 HB)
roll the inner part of the fender, they recommend this on very low cars to get the full camber adjustment.
Old Jan 29, 2002 | 05:54 PM
sgT's Avatar
sgT
Rolling the fender wont help, you need to trim the upper a-arm and part of the car.
Its not the fender, its a piece welded to the frame.
Old Jan 29, 2002 | 06:37 PM
fixhondas's Avatar
a 4 inch drop is too low- unless you get some drop forks and trailing arms
Old Jan 29, 2002 | 06:47 PM
fcuked's Avatar
Default Re: Just installed my camber kit, but it doesn't WORK. (sgT)
ok i am willing to trim some of the upper control arm but i really don't want to drill anything in the car, would that be possible?
Old Jan 29, 2002 | 07:03 PM
sgT's Avatar
sgT
try it and find out.
Old Jan 29, 2002 | 07:07 PM
fcuked's Avatar
what about these adjustable ball joints that they have? should i maybe buy those?
Old Jan 31, 2002 | 12:24 PM
hmonglonertim's Avatar
I had the same problem with those ugly ingalls camber kit on my 89 crx w/ only eibach springs (something like 1.5" drop). Get the ones with joints.
Old Jan 31, 2002 | 06:09 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Just installed my camber kit, but it doesn't WORK. (hmonglonertim)
forks.... you NEED them to drop your car that low and correct the camber w/o destroying something. 4" is pretty damn severe. a camber kit and the stock suspension stufffff won't work
Old Jan 31, 2002 | 06:44 PM
fcuked's Avatar
Default Re: Just installed my camber kit, but it doesn't WORK. (Pb_Foot)
how much do these forks cost and what exactly do they do, i really don't wanna modify the body of the car.
Old Jan 31, 2002 | 06:59 PM
Accord94DX's Avatar
I had the same problem with my accord. I had the speciality products camber kit for about 3 hours then I switched to the Offset balljoints. Those sockcucking things had a huge bolt on top that would smack the top of the inner fender. Finally I said " This is nucking Futs! I don't care if I go through 2 sets of tires a summer!" Cuz iM a BallAr, 20 inCh BlaDeZ oN dA imPAlA!
Old Feb 1, 2002 | 12:09 PM
89HF's Avatar
New User
The seam that your upper control arm hits can be modified-use tin snips to cut BETWEEN the spot welds(cut as far up as you can),use pliers to bend these tabs away from your UCAs,then hammer them flat and check for clearance-you may have to grind a little off the UCAs(watch those ball joints!)or set your kits so they have a little neg. camber if they still won't clear.Good luck!
Old Feb 1, 2002 | 01:27 PM
Jesse H's Avatar
Default Re: Just installed my camber kit, but it doesn't WORK. (89crxb16a)
raise the car. it'll ride, handle, and look nicer.
JDM_EjONE
Jul 18, 2007 05:51 PM
down_the_hatch
10
Feb 17, 2005 06:40 AM
91sihatchback
10
Jul 28, 2003 09:45 PM
fcuked
Jan 29, 2002 05:57 PM
