Tach & Speedometer Mechanics
Not on my Acura. The vehicle speed sensor sends electrical pulses to the speedo and odo driver circuits -- they're electrically driven. Same with the tach, which gets its signal from the igniter/coil circuit.
yep, on the earlier models (pre 90's) the speedo is mechanic - called a pulsar unit...
later models used teh VSS on the tranny to drive the speedo circut.
hope this helps?
PS why are you interested?
t..
hope this helps?
t..
Im still learning...but on a 90 CRX b16a....the vss sensor is in the tranny? I got a code 17...speedo works fine...but I can't figure out what to replace..the peice at the tranny..or new cluster?
My speed sensor is loose or something which causes my check engine light to come on. Does anyone know how to fix this? The repair manual says nothing. If I could locate it or see what it looks like then I could probably find one in a junkyard...
the way to fix it is to either get a new cable or try to use something to keep it from shaking out. if your speedo cable is out than you will not get vtec so its something you want to fix.
Hes saying hes got a bad connection...or broke speed sensor....if the cable was loose then his speedometer wouldn't work...am I right? is your speedometer working?
onefastasscivic
Jul 17, 2006 09:24 AM
