boosting 7 psi or less on stock injectors?
On stock injectors without any type of Fuel Management? I'm thinking either one of three things will happen.
1)Injectors Exceed their duty cycle - OUTCOME - Fail
2)Injectors cannot supply enough fuel - OUTCOME - Fail
3)Injectors squeeze through and provide enough fuel UNTIL you purchase some bigger injectors promptly - OUTCOME - Ghettofabulous/Good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRaping »</TD></TR><TR><TD CLASS="quote">is boosting anything under 7 psi with the stock ecu and injectors ok? this is a greddy kit but without the blue box.</TD></TR></TABLE>
No, it's not going to happen.
Stock injectors on a stock setup are already maxed out. The only way to get more out of the stock injectors is by using an FMU and inline fuel pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">Stock injectors on a stock setup are already maxed out</TD></TR></TABLE> I wouldn't go as far as saying that, because we all know that injectors operating past their efficiency rating (85-100% Duty cycle) will not last on the order of 15-16 years; either that or my injectors are smoking meth and can't feel the pain.
1SickHb
Dec 9, 2005 08:13 AM
