Dyno # of my Skunk2 Pro1 cams Using Neptune
Old Apr 13, 2005 | 01:36 PM
vinasity's Avatar
Default Dyno # of my Skunk2 Pro1 cams Using Neptune
So i went to titan motorsports today and met up with darin to get my pro1 cams tuned.I only had it tuned for an hour since funds are low so here is my mod list
00b18c1
ebay intake
jdm 4-1 header
tanabe exhaust
jdm ITR pistons stock bore
Skunk2 IM
Skunk2 pro1 cams
Omnipower valvesprings & retainers
jun cam gears 0,0
The beater
Dyno numbers after 3 or 4 pulls
Thanks to Darin and neptune i think my numbers came out pretty good for only an hour of tuning. and my cam gears are still at 0,0 i think it still has more potential with some more dyno time.
Ps. After some of the pulls the car would idle funny darin thought that it might be my valve lash which is at 7 and 8 does anyone have an opinion on this?
Modified by vinasity at 12:11 AM 4/14/2005
Old Apr 13, 2005 | 01:42 PM
STEV3-O's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (vinasity)
damm, looks like good number to me
JoeB18R's Avatar
lol no VTEC spike
torque seems low. I made 130 with B16A2 cams.
what compression is all this at?
Old Apr 13, 2005 | 01:53 PM
PreStaged12s's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (JoeB18R)
damn man, thats hella good, whats the cr on that motor, like 11.5?
Old Apr 13, 2005 | 02:02 PM
vinasity's Avatar
compression around 11.3
Old Apr 13, 2005 | 02:12 PM
HRTuning's Avatar
Default Re: (vinasity)
Definitely has more potential if the cam gears are still 0,0... Good stuff...
Old Apr 13, 2005 | 02:15 PM
Hybrid ctr's Avatar
Default Re: (HRTuning)
Great numbers!!!
Old Apr 13, 2005 | 02:16 PM
91sihatch's Avatar
Wow awesome #'s
Looks like it was still making power when you shut it down.
Old Apr 13, 2005 | 02:28 PM
sheepey's Avatar
nice!
Old Apr 13, 2005 | 02:39 PM
ptoledo's Avatar
great numbers!!
Old Apr 13, 2005 | 03:53 PM
moto1320's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (aLLMotorDB8)
Nice! I'm really glad you posted this. It's the same setup that I am about to build except .25 over on the pistons. I'm hoping that a good valve job and a different header will cross me past the 200 mark. Did you do anything to the head? I may go with flat faced valves too after seeing this. Post up after you get those cam gears dialed in.
Those bigger primaries do make the transition over to the big lobes smooth apparently. How's it drive? Any pro's or cons you'd like to point out on those cams? They looked really good on the other dyno I saw posted up but it was a pretty aggressively modded engine. I had been hoping to see one with a more OEM setup and Pro 1's Thanks again.
Old Apr 13, 2005 | 03:57 PM
dragit909's Avatar
Old Apr 13, 2005 | 04:33 PM
AdamBOMB_STi's Avatar
AWESOME, u have the same setup im gonna do so far i have the bottom end squared away. now i need the head built and the cams. hmm looks like ill need a dtr header and a bored tb to get it over 200. im trying to break 200 with the stock gsr im. btw awesome setup, lovin the VTAK crossover! yes i said VTAK (inside thing) lol
Old Apr 13, 2005 | 04:34 PM
TrackSpeedRacing's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (DC_deuce)
those are some really good numbers
Old Apr 13, 2005 | 04:59 PM
chameleon's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (1320JDMGSR)
nice man i was waiting for someone to finally have these babies and dyno them. from the power you laid down i think thats a good foundation with more room to go.
i basically have 12.8:1 compression, mild port and itbs so im hoping to have 10+ hp over ya. just waiting for my ems to tune.
Old Apr 13, 2005 | 05:26 PM
DIFFUT'S INC.'s Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (chameleon)
nice #
Old Apr 13, 2005 | 06:25 PM
kadburry's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (DIFFUT'S INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIFFUT’S INC. &raquo;</TD></TR><TR><TD CLASS="quote">nice #</TD></TR></TABLE>
guess im gonna go with some itr pistons in my build too
Old Apr 13, 2005 | 07:15 PM
rjay8604's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (kadburry)
Nice, looks like the tuners have a good time using neptune. So all you have is a obd-1 socketed ecu for the neptune, you don't have a datalogging port or something for them to extract data. Is it just a chip and wideband dyno tuning?
Great numbers by the way.
Old Apr 13, 2005 | 08:14 PM
MikeSarr_GSR's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (rjay8604)
definately time to put down some runs what tranny setup do you run with that power?
Old Apr 13, 2005 | 08:37 PM
DOHCsideracing's Avatar
Nice numbers
Damn I'm going to be running a very similar set-up (is there an echo in here???)I'm running the Pro 1's, SRP .5mm OS 11:1's with some Omni flat valves and springs, to put me at around 11.5-11.7:1, Hondata, and a ported B16 mani. on a milded ported GS-R head (I know the B16 mani doesn't fit a C1 head, but I fabbed it to fit), a AEM SRI, and some cheap 4-2-1 header, and a 2-3/8 exhuast...
I think the I'll be a little shy of your numbers after tuning (b/c of the header and smallish exh), but if I'm 190+ I'll be happy, but this gives me a good idea on how it will run
Again, nice numbers,
Adrian
Old Apr 13, 2005 | 08:42 PM
2k.civic.si's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (DOHCsideracing)
nice numbers....whats the specs on those pro1's?
Old Apr 13, 2005 | 09:52 PM
vinasity's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (moto1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto1320 &raquo;</TD></TR><TR><TD CLASS="quote">
Those bigger primaries do make the transition over to the big lobes smooth apparently. How's it drive? Any pro's or cons you'd like to point out on those cams? They looked really good on the other dyno I saw posted up but it was a pretty aggressively modded engine. I had been hoping to see one with a more OEM setup and Pro 1's Thanks again.</TD></TR></TABLE>
The crossover to vtec does not seem that extreme becaue of the size of the primary lobes. The pros are that my motor feels bigger becaue of the wider power band and the horsepower is good. Cons arer the idle is a little rough and tuning them. But damn is my car a lot louder now that i have these cams
Old Apr 13, 2005 | 09:54 PM
vinasity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">Nice, looks like the tuners have a good time using neptune. So all you have is a obd-1 socketed ecu for the neptune, you don't have a datalogging port or something for them to extract data. Is it just a chip and wideband dyno tuning?
Great numbers by the way. </TD></TR></TABLE>yeah i have a socketed p28 he just took out my old chip and gave me a better setup
Old Apr 13, 2005 | 10:31 PM
biassj's Avatar
Good numbers! I have a set, but mine motor is a B20, hopefully dyno in the future.
Old Apr 14, 2005 | 12:02 AM
ek9800's Avatar
Default Re: Dyno # of my Skunk2 Pro1 cams Using Neptune (biassj)
Damn those are some good numbers
How you liek Neptune? I'm thinking of going with it as well.
