need a d16z6 block
Old Apr 13, 2005 | 12:22 PM
rsca_crx's Avatar
Default need a d16z6 block
this is a wtb thread, but i thought i might have some better luck here and find someone that needs to get some crap out of their garage. do what you need to do vap.
after punching a rod through the block girdle, my buddy needs a complete d16z6 bottom end. looking for something complete and still assembled so we can put his head on it and go. other ideas are welcomed (complete motors, whatever), and cheap is good.
lemmeno what you got.
Old Apr 13, 2005 | 01:13 PM
dr_latino999's Avatar
Default Re: need a d16z6 block (rsca_crx)
Wait till Vap gets home, someone is going to get the hammer --> <-- IBTL
Old Apr 13, 2005 | 02:44 PM
slpnz6's Avatar
i have a bare z6 block, and a semi-complete head, its port n polished, needs to bo torqued to spec and needs a dizzy. ill letm go for dirt cheap. 300.00 for both......also the head was milled .05mm for a hi-comp build up i was gonna do...i ended up getn a b16...
Old Apr 13, 2005 | 02:48 PM
Irish Integra's Avatar
The ZC SOHC block is the same as a D16Z6, I've just fitted the head from a D to a ZC block for the same reasons as yourself (and she ran for the first time about half an hour ago ).
The only problem I found was a slightly different angle on the l/h engine mount (may have to use the doner mount and bracket). After that I just fitted the blanker plug for the coolant temp. sensor and fitted the thermostat housing and pipe over from the D because the temp. sensor is on the 'stat housing. Also there's a valve in the oil gallery on the ZC motor going to the head which you remove, it just slips out. Other than that it's just the usual few brackets.
Hope this is of some help.
Old Apr 13, 2005 | 02:50 PM
Default Re: need a d16z6 block (Irish Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irish Integra &raquo;</TD></TR><TR><TD CLASS="quote">The ZC SOHC block is the same as a D16Z6, I've just fitted the head from a D to a ZC block for the same reasons as yourself (and she ran for the first time about half an hour ago ).
Hope this is of some help.</TD></TR></TABLE>
I.E. an Irish Mini-Me
Old Apr 13, 2005 | 03:09 PM
bagpipe goatee's Avatar
actually, the sohc zc block is exactly like the d16a6 which are both similar to the z6. just widening your search, cause a6's are easy to find.
Old Apr 13, 2005 | 03:19 PM
Default Re: (bagpipe goatee)
Do SOHC VTEC motors have oil squirters like their DOHC brethren?
Old Apr 14, 2005 | 06:11 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">actually, the sohc zc block is exactly like the d16a6 which are both similar to the z6. just widening your search, cause a6's are easy to find.</TD></TR></TABLE>
so who needs to clean out their garage?
again, Vap- feel free to delete or move if you feel the thread is in poor taste.
Old Apr 16, 2005 | 09:19 PM
correct me if i'm wrong, i could very well be, but the sohc vtec motors do not have the oil squirters in the block, they have a similar regulator in the head. but it needs more oil for vtec to engage than will fit through the squirter, so therefore its in the head where it can be controlled.
24TEN
36
Jan 4, 2014 05:55 PM
ekb16a
Sep 1, 2009 11:33 AM
kiddcheng
Apr 11, 2004 04:47 AM
