Torque Steer (sp?) on my Type S =(
Is that normal to have torque steer in 1st gear? Do you guys experience the same thing often? The car pulls a lil to the right when I first accelerate.
Would an LSD help?
Please help me out here, I've never really experienced this much of it before.
Would an LSD help?
lol...are you serious? You have a higher powered FF platform...what did you expect? You should try the CL-S with the VSM turned off...lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls »</TD></TR><TR><TD CLASS="quote">Yes we all experience it. LSD will minimize it.
Thanks =]
Thanks =]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBRF4i »</TD></TR><TR><TD CLASS="quote">Torque steer just makes things more interesting</TD></TR></TABLE>
hahahaha, and bump steer keeps you guessing. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tom5 »</TD></TR><TR><TD CLASS="quote">
hahahaha, and bump steer keeps you guessing. lol</TD></TR></TABLE>
LOLOLOL, so true. Gotta love the tie rod angle after you lower the car.
Im working on a fix for that one....if I can ever find time grrrr.
It can also be caused by and open diff since one wheel spinning and the other gripping is obviously going to have an effect on steering. An LSD WILL help torque steer caused by this. Last time I checked the EP3/DC5 chassis DOES have equal length halfshafts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon »</TD></TR><TR><TD CLASS="quote">LOLOLOL, so true. Gotta love the tie rod angle after you lower the car. Im working on a fix for that one....if I can ever find time grrrr.</TD></TR></TABLE>
Have you tried the inverting the tie rod ends?
Thats what im going to be doing. Since theyre a taper fit I just need to find the right size spherical rod end stud to do it and drill it out. I simply havent had the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon »</TD></TR><TR><TD CLASS="quote">It can also be caused by and open diff since one wheel spinning and the other gripping is obviously going to have an effect on steering. An LSD WILL help torque steer caused by this. Last time I checked the EP3/DC5 chassis DOES have equal length halfshafts. </TD></TR></TABLE>
If one wheel is spinning, then you're right about an LSD helping.
You're right, the EP3/DC5 DO have equal length halfshafts.
Most people complain about torque steer when cornering. I believe that it's actually bump steer that they're feeling and has to do with the suspension geometry. It will be worse the more your car is lowered.
