crank pully machining
Old Apr 13, 2005 | 09:28 AM
balbowskie187's Avatar
Default crank pully machining
i have a h23a1 engine in my lude. i am also a machinist w/ access to good machines. on my stock crank pully, would it be possible to shave off the power steering portion of the pully, maybe even drill the pully for further weight loss? does anyone know if this would work or better me or done this befor? i dont wanta junk the pully cutting it up. i was thinking that it may throw the balance of the pully off, or i would've done it by now.
Old Apr 13, 2005 | 03:34 PM
RHD_BB4T's Avatar
Default Re: crank pully machining (balbowskie187)
There are several companies that do this. As long as you retain the stock balance of the pulley, I wouldn't see where any issues would arise... I say go for it!
Old Apr 13, 2005 | 04:34 PM
flyrod's Avatar
Default Re: crank pully machining (RHD_BB4T)
ya, you should be fine. A local guy couldn't get the pulley off when putting a h22 in a crx, so they cut off the PS part with a hand grinder. Not pretty, but it worked fine. With a nice lathe, I bet yours will come out nice.
Old Apr 13, 2005 | 04:50 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: crank pully machining (flyrod)
Well the pulleys are balanced from the fatory so would'nt cutting something off disturb this balance????
Old Apr 13, 2005 | 06:26 PM
Under_Pressure's Avatar
balbowskie187 this is your second topic on pullys. Leave them alone dont expect to get good power out of them. Spend your money wisely.
Old Apr 13, 2005 | 07:06 PM
The Phil's Avatar
Default Re: crank pully machining (92h22alude)
If you chopped off the power steering part, you should be fine. Get it done with a computer-controlled tool of some sort and the balance should be fine. I wouldn't go around punching holes in the pulley though.
ilovemydc5
Feb 2, 2007 01:24 AM
tonylphie
Sep 28, 2004 08:38 PM
japspecjohn
27
Nov 3, 2003 06:13 AM
mdpalmer
Jul 27, 2003 03:10 PM
Bnjmn
Jul 7, 2002 02:17 PM
