how to chip a pr3 ecu?
There is tons of info at http://www.pgmfi.org Read and learn.
If you're not comfortable taking the iron to your ecu, I might know someone who can perform that service...
all i have to do i think is remove the 28 pin chip and put the hondata one in. then put the 4 pin adapter for datalogging in the cn3 spot. am i right or am i missing something? thanks
um hondata wont work with your pr3.. you need a obd1 and above type ECU.
the pr3 you have is obd0 unless you have a SiR II obd1 and obd1 ecu. chnageover which i doubt.
the only ECU program and standalone/piggybacks for obd0 is TurboEdit that i know of,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner »</TD></TR><TR><TD CLASS="quote">um hondata wont work with your pr3.. you need a obd1 and above type ECU.
the only ECU program and standalone/piggybacks for obd0 is TurboEdit that i know of,</TD></TR></TABLE>
The old Hondata staged system will work with the PR3. However, it has been discontinued and Hondata no longer offers support for it.
can I use an OBD1 chipping kit in an OBD0 ECU. I guess all I need is the ZIF socket and the ECU chip. where would I find the stock pr3 rom. im trying to remove the knock sensor code from a PR3.......
