Electrical Problem – Car dies?
Old Apr 13, 2005 | 07:55 AM
rs's Avatar
rs
Default Electrical Problem – Car dies?
I have had two occurrences of my car just shutting off in the past couple of weeks. It not only shuts off, but I loose total power to my car (clock is reset, radio reset). Both times I was sitting at stop lights and all of a sudden the car goes dead. The car starts up fine afterwards. (I hoping this does not happen on the highway!)
Modifications / Recent items
- I have installed a cassette deck radio (Acura OEM) so I can use my iPod.
- My car is stripped in the back and there are those wires back there that I constantly put stuff on (probably not the best idea)
- I checked my battery connections. They are fine.
Anyone have any ideas as to diagnosing the problem?
- Adam
Old Apr 13, 2005 | 09:10 AM
Chris F's Avatar
Default Re: Electrical Problem – Car dies? (rs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rs &raquo;</TD></TR><TR><TD CLASS="quote">I have had two occurrences of my car just shutting off in the past couple of weeks. It not only shuts off, but I loose total power to my car (clock is reset, radio reset). Both times I was sitting at stop lights and all of a sudden the car goes dead. The car starts up fine afterwards. (I hoping this does not happen on the highway!)
- Adam
One time I had something like this, it ended up being a short near the battery .
I would start wiggling wires, maybe not while the car is running, but with the parking lights on. See what you move that makes the power go off. Start at the battery, check the ground straps and the fuse box. If you wiggle something and the power goes out, you found the culprit. With the parking lights on, you should be able to see or hear a small spark if something is loose.
Old Apr 13, 2005 | 09:12 AM
rs's Avatar
rs
Default Re: Electrical Problem – Car dies? (Chris F)
Thanks - I'll give that a try tonight.
Old Apr 13, 2005 | 09:21 AM
Dave-ROR's Avatar
Adam you have an ITR again? What happened to the cadavalier?
Damn.. long time since I've seen your name on here.
Old Apr 13, 2005 | 10:09 AM
hYpE-R-29's Avatar
Default Re: Electrical Problem – Car dies? (Dave-ROR)
maybe your battery or alternator...Check alternator by leaving the car idle and yank out the positive side of the battery..if it dies, alternator problem..goodluck
Old Apr 13, 2005 | 10:13 AM
rs's Avatar
rs
Hey Dave,
While I was in NYC the R was in my sister's garage. The "cadavalier" was my NYC beater. Now my girl drives it. Also, I bought a house here in Tampa - close to the house you stopped by once. I need to get back in the car thing again. Let me know what's going on in the area. My tranny needs to have some new sycros, but beside's that the R is doing good.
Old Apr 13, 2005 | 10:59 AM
Chris F's Avatar
Default Re: Electrical Problem – Car dies? (hYpE-R-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">maybe your battery or alternator...Check alternator by leaving the car idle and yank out the positive side of the battery..if it dies, alternator problem..goodluck </TD></TR></TABLE>
I wouldn't do that.
Old Apr 13, 2005 | 11:02 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't do that.</TD></TR></TABLE>
why not? Thats a good test for it
Old Apr 13, 2005 | 11:09 AM
Chris F's Avatar
Default Re: Electrical Problem – Car dies? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">why not? Thats a good test for it</TD></TR></TABLE>
First, it couldn't be the alternator, based on the original description.
Second... there's not enough capacitance in the system without the battery, the alternator's fluctuating voltage could fry the ECU.
Accurate way to test alternator is with a voltmeter (battery should be ~14 volts when the car is running.) But the battery idiot light does a pretty good job of catching bad alternators.
Reference:
http://www.fordscorpio.co.uk/electsystemtest.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ford &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red">NEVER DISCONNECT THE BATTERY WITH THE ENGINE RUNNING AS SEVERE DAMAGE WILL RESULT.</FONT></TD></TR></TABLE>
[edit: This was a good test, back in the day, but I wouldn't do it with modern electronics]
Old Apr 13, 2005 | 02:40 PM
hYpE-R-29's Avatar
it would not fry the ecu ORELSE you can never jump any car......try it man
Reference:
Old Apr 13, 2005 | 02:44 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">it would not fry the ecu ORELSE you can never jump any car......try it man </TD></TR></TABLE>
You can jump a car because there's TWO batteries in parallel in the system, one of which can provide current to start the other car (besides that, the jumping car can charge the dead battery). The spikey output of either/both alternators are smoothed by the batteries.
If you take the battery off, the alternator will be generating a bunch of spikes of current as it spins. It doesn't put out a nice smooth 14V. if you have a 1 farad cap on your stereo, it would be OK, because that can smooth it out pretty well just like a battery could. If not, you're gonna **** off electronics, because the voltage is going to jump between 14 and 0 really quickly.
Still-- there's ZERO chance that this is his alternator, and if it was his alternator, it could only be an intermittent short in the alternator that this test wouldn't catch.
-faded-
Audio / Security / Video
Sep 29, 2004 04:33 AM
honda_joe
Nov 20, 2003 12:45 PM
kcivic
Nov 11, 2003 12:29 AM
krazy
20
Jun 5, 2003 12:52 AM
