Has Anyone used ACL rod bearings in ls/b20 rods?
Old Apr 13, 2005 | 07:05 AM
ek2k's Avatar
Default Has Anyone used ACL rod bearings in ls/b20 rods?
wat up everyone has anyone in here used ls/b20 acl bearings in eagle rods in a b20? most people are going with oem i know but i already have ACL's tried putting them in the other day but they seemed like i had to go one step down with those (but to my knowledge ACL's is one size fits all) right? lol well i know honda bearings are $$ can anyone tell me what they usually come out to as in total? and estimate would be great.. and if someone in here is running those ACL's bearings did they have any trouble with them and how long have you been running your motor for i wanna see the durability and lifetime on these please help!!
Old Apr 13, 2005 | 07:06 AM
ek2k's Avatar
Default Re: Has Anyone used ACL rod bearings in ls/b20 rods? (ek2k)
oh yes and i did research for about half an hour and all i came up with was that most of you are running oem's and well not a lot of peeps went into detail if they were running ACL'S and how it worked please advise...
Old Apr 13, 2005 | 08:25 AM
ek2k's Avatar
someone.
Old Apr 13, 2005 | 08:38 AM
5STAR3's Avatar
some of the most knowledgeable tuners/builders on this forum chimed in on this thread
https://honda-tech.com/zerothread?id=1128143
Old Apr 13, 2005 | 09:00 AM
ek2k's Avatar
Default Re: Has Anyone used ACL rod bearings in ls/b20 rods? (envision2teg)
please do. i understand if you have ACL's well you have to plastiguage them correct?
Old Apr 13, 2005 | 09:01 AM
nonvtecD's Avatar
The motor I am currently building I am using ACL rod bearings with LS rods. I reconditioned the rods myself so my clearances were perfect.
Old Apr 13, 2005 | 09:11 AM
5STAR3's Avatar
Default Re: (nonvtecD)
right, have the big end machined.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2k &raquo;</TD></TR><TR><TD CLASS="quote">please do. i understand if you have ACL's well you have to plastiguage them correct?</TD></TR></TABLE>
you dont have to do anything
but you are correct, you need to check your clearances. plastigauge probably being the most barbaric way, but still pretty effective.
Old Apr 13, 2005 | 09:30 AM
ek2k's Avatar
Default Re: (envision2teg)
how much is expected to cost if i have them machined? does this apply to my rods since i am using eagle rods?
Old Apr 13, 2005 | 11:24 AM
ek2k's Avatar
Default Re: (ek2k)
bump !
Old Apr 13, 2005 | 12:06 PM
5STAR3's Avatar
Default Re: (ek2k)
i think i paid $65 to have my rods sized.
i dont know much about the sizes of aftermarket rods. do they come with any specs on the large end? if not have them measured, and if need be resized.
Old Apr 13, 2005 | 01:07 PM
nonvtecD's Avatar
Your Eagles should probably be dead on. Check the clearances then decide if they need it.
Old Apr 13, 2005 | 01:49 PM
ek2k's Avatar
Okay here is my last question when i tighten my arp rod bolts to my final pounds which is 28flbs i dont get there because as soon as i get to 23flbs the rod bearings start getting tight and look like they might crack so i stopped could it be me that i have the bearings flipped and i should try the other way and switch the bearings from bootm to top? are they diff? thanks for all the help...
Old Apr 13, 2005 | 04:06 PM
5STAR3's Avatar
Default Re: (ek2k)
check it with a rod bolt stretch gauge.
Old May 21, 2005 | 09:55 PM
whatVTEC's Avatar
Lemme know if you need some OEM ones, I have a bunch left over from my build
Old May 21, 2005 | 10:05 PM
sheepey's Avatar
what is the part number on the box for ur bearings?? I use to work for ACL and know their product very well. And no there isnt 1 size fits all. They work great and never had a problem selling them to J.J from PFI and Sam from Import Sports
Old May 22, 2005 | 06:19 AM
MI4$DC5's Avatar
Default Re: (sheepey)
im running ACL bearing in my b20vtec set up. my mechanic said i should be good with those. I had all my clearances and stuff checked also.
BMo Tuning
26
Mar 20, 2012 10:09 AM
supra-n-civic
Nov 30, 2009 08:03 AM
smileycvc
Mar 9, 2007 12:30 PM
Turbocivic94
Jul 15, 2004 05:40 PM
lsvtecvx
Apr 2, 2003 07:13 PM
