question in screw changing
Old Apr 13, 2005 | 06:54 AM
StOnErTuNinG's Avatar
Default question in screw changing
i need to change the crankshaft pulley screw is there anything i need to know like the crank will fall can i get instruction in change it
Old Apr 13, 2005 | 06:57 AM
UNKNOWN_MEMBER's Avatar
You mean the crankbolt? When you take out the bolt, remove the the pulley. Keep an eye on it, there will be a little peice of metal, shaped like a retangle, it's the key. Then just put the key back in and put the pulley on and tighten the bolt down. I'm not sure how tight, but I know you're going to tighten it ALOT.
Old Apr 13, 2005 | 07:29 AM
Default Re: question in screw changing (CIVICGEN2)
AND DOES THE BOLT MATTER LIKE IF U USE A B16 OR GS-R ON A TYPE -R MOTOR
barrera
Oct 11, 2010 07:17 AM
His_Dudeness
Sep 2, 2010 06:11 AM
prelude1897
Jul 11, 2006 03:11 PM
hypnotixcrx
Mar 19, 2005 08:51 PM
hatchdrvr
Feb 13, 2003 04:07 PM
