Supertech Spring - Too much seat pressure?
Old Apr 13, 2005 | 06:41 AM
ELSpool's Avatar
Default Supertech Spring - Too much seat pressure?
My head guy just called and told me there is too much spring pressure, almost 70lbs, when the sheet says just over 50 lbs. Anyone else have issues with this?
D16Y8 head
ST .5mm bigger In/Ex Valves - cut for 3 angles
ST Springs
ST Retainers
I bought the package through Earl and have seen it installed on a few other members, but not hear any bad feeback? Should I be worried?
Modified by ELSpool at 4:47 PM 4/13/2005
Old Apr 13, 2005 | 07:43 AM
JDMCRX's Avatar
Default Re: Supertech Spring - Too much seat pressure? (ELSpool)
**** thats alot more presure does anyone else have these springs?
Old Apr 13, 2005 | 07:54 AM
yellowturbo's Avatar
maybe that your head guy have a wrong scale ?
Old Apr 13, 2005 | 09:22 AM
platinum00's Avatar
i use the supertech springs in my y8 head, and i did not have that problem. i forget what the pressure was, but it was not 70.
Old Apr 13, 2005 | 01:35 PM
ELSpool's Avatar
Default Re: Supertech Spring - Too much seat pressure? (platinum00)
I spoke with ST, they said I'm fine with that pressure. But I'm getting close to coil bing with the Zex cam. Is there a rule that you should not go to close to the max bound of a spring? Right now my coil bind is 1.360 and my height is 1.85 which leaves me with .490 (spring height minus CB)
Now the Zex cam is .455 lift, is the .35 difference too close?
Old Apr 13, 2005 | 06:29 PM
ELSpool's Avatar
anyone?
Old Apr 13, 2005 | 08:35 PM
The Meat's Avatar
Default Re: (ELSpool)
Which cam are you installing? I have the Supertech set up from Earl as well. I also have Zex's new 59500 cam(sorry dont have the specs right now) but I know it has alot of lift to it but is still on the 111 LSA, same as the 59300 cam.
Old Apr 15, 2005 | 04:32 AM
platinum00's Avatar
Default Re: (NSP)
yea i have the same setup and dont have bind.
im going to call my engine builder today and see if he remembers what the pressure and bind was.
Old Apr 15, 2005 | 04:50 AM
ELSpool's Avatar
Also ask for Spring height too, and not whats on the spec sheet..
Old Apr 15, 2005 | 05:06 AM
damn just keep your stock spring like last summer ? it was working great !
Old Apr 15, 2005 | 05:16 AM
ELSpool's Avatar
Don't trust them over stock redline.
Old Apr 15, 2005 | 06:37 AM
platinum00's Avatar
Default Re: (yellowturbo)
hey yellowturbo, how's the car running
EG-SIXV-TEC
Nov 18, 2012 07:32 PM
Rocket
91
Feb 3, 2012 07:28 PM
7rrivera7
Sep 22, 2008 10:29 AM
Pfieff
Sep 7, 2004 10:00 AM
