People that know about junk yard turbos......need advice on which turbo to get
Old Jan 29, 2002 | 02:30 PM
wickedxboi's Avatar
Default People that know about junk yard turbos......need advice on which turbo to get
i went to the junk yard today and found 3 turbos
garrett off a 89 volvo ( A/R .42? )
ct26 off a 91 mr2 turbo
one off a 92 talon
Can somebody give me some info on which one to pick? how can i tell if its still good? Im tryin to build a turbo kit for my b17 (93 gsr). thanks
Old Jan 29, 2002 | 04:57 PM
wickedxboi's Avatar
Default Re: People that know about junk yard turbos......need advice on which turbo to get (wickedxboi)
anybody?
Old Jan 29, 2002 | 05:35 PM
dbman96's Avatar
New User
Of the three, the 92 Talon is probably the best one but if you aren't in a huge rush, you could wait to find one of the following:
Thunderbird Turbo Coupe
Merkur XR4ti
Mustang SVO
Ideally find one of these cars with a 5-speed tranny as it will have the less restrictive 0.63 turbine.
All these three (anyone add any to this list?) come with the T3 super-60 compressor which will spool faster than most turbo kits out there and still flows ALMOST as well (looking at the compressor maps I would say it's better matched to our motors than any T04E but empirical evidence shows otherwise). This will be a kick *** turbo that won't leave you with "NEED MORE TURBO" syndrome when you're done, and then when you DO need another turbo you can just swap for a larger T3/4 hybrid and keep ALL your existing piping (manifold, downpipe, etc) when you upgrade.
Old Jan 29, 2002 | 05:40 PM
FBP Ex-T's Avatar
Default Re: People that know about junk yard turbos......need advice on which turbo to get (dbman96)
are those the only cars that come w/that turbo?? are they internal (plz say yaa!!!)
Old Jan 29, 2002 | 05:44 PM
dbman96's Avatar
New User
Default Re: People that know about junk yard turbos......need advice on which turbo to get (FBP Ex-T)
Internal?? They have an internal wastegate if that's what you're asking... I'm not sure on other applications. I know Ford diesel trucks run some trim of T-3 but I'm not sure what compressor is on it. Considering the difference in displacement between a ford super duty and an Integra it's probably not a very good match.
Old Jan 29, 2002 | 05:48 PM
FBP Ex-T's Avatar
i need an internal wastegate turbo lol
Old Jan 29, 2002 | 06:09 PM
dbman96's Avatar
New User
Yeah that one or just about any "junkyard" turbo should have an internal wg.
Old Jan 29, 2002 | 06:23 PM
AbaZ's Avatar
IT really depends on what motor you are going to put it on.. the Mr2/Volvo turbo are going to be to small for a larger B-series motor.. The 14b (TDO5h) Mitsu can just do fine on a B-series.. all these turbos are internally gated.
If you can get the 14b cheap, pick it up.
Jeff Frank
Old Jan 29, 2002 | 07:38 PM
5gen-hybrid's Avatar
New User
Default Re: People that know about junk yard turbos......need advice on which turbo to get (AbaZ)
saab's also have a garrett t-3 turbo.The older ones are oil cooled and the newer ones are water and oil cooled.I'm not sure on the specks (if anybody knows please inform me) but they are awsome for the sohc (it's equal to a t3t4 hybrid on a b series) and just as good on a b series because they spool pretty fast.
Old Jan 29, 2002 | 07:39 PM
New User
Default Re: People that know about junk yard turbos......need advice on which turbo to get (5gen-hybrid)
Oh and they bolt rite up to a drag manifold perfectly (compressor to block clearances) and they are both t-3 flanges.
Old Jan 29, 2002 | 07:40 PM
wickedxboi's Avatar
abaz
which 1 is the 14b?
would the turbo off the eclipse be just right for my b17a or is it to small? (93 gsr)
[Modified by wickedxboi, 4:43 AM 1/30/2002]
chrisgottigsr
Jan 2, 2006 04:45 PM
CSRacing
Oct 19, 2005 05:27 AM
tSuperbike69
Sep 12, 2002 06:36 AM
