would bad knuckle cause vibration
Old Apr 12, 2005 | 07:15 PM
Bobby808's Avatar
Default would bad knuckle cause vibration
I just had a b16 swapped into an crx hf and had a bad vibration at speeds of about 55+mph. I had wheels balanced and which helped get rid of most of vibration. I can still feel some vibration though especially from drivers side front. To my question now, the knuckles that I swapped did not have the greatest bearings and I was wondering if this could cause the vibration that I am feeling?
Old Apr 12, 2005 | 07:45 PM
bagpipe goatee's Avatar
yes, thats probably it. bad bearings will definitely cause vibration. if you don't have the funds to get a new bearing pressed in, i'm sure a knuckle wouldn't be too hard to find used from a friend or a junkyard or something.
Old Apr 12, 2005 | 08:54 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (bagpipe goatee)
it might be ball joints too, i had bad ball joints in a 84 prelude and the front end shook out of control anywhere above 60mph..
bearings are also a good idea to check, but usually when those go you have a lot of screetching and strange noise coming from one side or the other.
canadaek
Transmission & Drivetrain
Nov 6, 2012 02:05 PM
aquafresh93
10
Jun 28, 2009 05:57 PM
JUN.
Jan 1, 2006 12:39 PM
crexer
Sep 1, 2005 02:23 PM
impr323
Mar 6, 2005 01:12 PM
