Does changing you altenator require you to remove or mess up timing or timing belt?
Does changing you altenator require you to remove or mess up timing or timing belt? Or when you change your altenator, you just have to take off the alenator pully belt and nothing else.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {StatuS ChecK} »</TD></TR><TR><TD CLASS="quote">when you change your altenator, you just have to take off the alenator pully belt and nothing else.
Thanks.</TD></TR></TABLE>
timing is not affected
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">
timing is not affected</TD></TR></TABLE>
Thanks alot yall, I just wanted to clear everything up before the procedure Tomorrow!
imadigitalgod
Aug 18, 2023 08:01 PM
