New Setup
My brother just finshed his engine.. in his 91 integra four door...
B18a1 Block
0.25 Oversized CTR Pistons
Short Peened LS Rods
STR Block Gaurd
Balanced B18a1 Crank
OEM Honda Bearings
ARP Rod Bolts
GSR Water Pump
B20 Oil Pump(same part # as GSR)
GSR Timing Belt
ARP Head Studs
B18a1 HeadGaskert
LS/VTEC Oil Line Kit
B16a2 Complete Head
OBD0 B16a Distributor
OBD0 B16a Fuel Injectors
Civic Type R Cams
Civic Type R Valves, Springs, Retainers..
DCS 4-2-1 Header
Comptech Intake
2.25" Exhaust
Apexi V-AFC
Still Breaking in motor so no times yet..
PR3 B16a ECU
B18a1 Block
STR Block Gaurd
OEM Honda Bearings
ARP Rod Bolts
GSR Water Pump
GSR Timing Belt
ARP Head Studs
B18a1 HeadGaskert
B16a2 Complete Head
Civic Type R Cams
DCS 4-2-1 Header
Comptech Intake
2.25" Exhaust
Apexi V-AFC
PR3 B16a ECU
nice setup. are you looking to upgrade your valvetrain and cams to compliment that compression? also better management like hondata,chrome, etc.? update with dyno #'s
rev-speed
87
Dec 1, 2007 03:55 PM
slowazzhatch
Jul 15, 2003 01:41 PM
