MY CRX should be running sooon!!
Old Apr 12, 2005 | 05:44 PM
Autoworks's Avatar
Default MY CRX should be running sooon!!
MY buildup is finally starting to come together. I bought my 88 CRX HF 11/28/04 and have been slowly working on it since. I got it with a blown headgasket, broken timing belt, no wheels, a vented hood, and a bunch of riced out sh... )like the homemade painted supra style rail lights )
The motor is being dropped now. It is...
B16A, AEBS intake mani., BBK 62mm TB, Fidanza flywheel, NKK clutch, CTR N1 pulley, Megan header (w/ 2 02s), and a PR3. I'm using LS knuckles, axles, tranny, brakes and rotors.
I had to call Hasport today to get the subharness overnited, but other than that there have been no seriouse hangups, other than I'm missing 3 pressure plate bolts. Hopefully I can have some pics up soon.
Old Apr 12, 2005 | 05:49 PM
kulangot's Avatar
Default Re: MY CRX should be running sooon!! (Autoworks)
sounds like you have a nice setup...good luck.....
doublethink's Avatar
you just described my setup, im runnign stock intake manifold and an RS*R cat back, but otherwise
the cars getting rear discs and a valve adjustment this week...
i have no lift or an air compressor so i took it to this guy i know, but i miss my car
Old Apr 12, 2005 | 05:53 PM
Autoworks's Avatar
Default Re: MY CRX should be running sooon!! (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have a nice setup...good luck..... </TD></TR></TABLE>
Thanks, I'm sure there will be new drama tomorrow-I have to locate a LS RF caliper. Honda wanted $180 plus a core Time to hit the phones in the A.M
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">you just described my setup, im runnign stock intake manifold and an RS*R cat back, but otherwise
Yeah, I have nothing back No exhaust, my stock cat and midpipe is laying on my porch. I will be taking it straight to the muffler shop. I plan on running the 18" polished magnaflow w/ 2.5" piping and resonator.
Old Apr 12, 2005 | 09:03 PM
sounds good
post up some pics
Old Apr 12, 2005 | 09:05 PM
CRX_1.8T's Avatar
It is such a good feeling when things start coming together on your CRX. Good to see that things are going good bro! Your gonna have tons of fun with her when its all done.
Old Apr 13, 2005 | 05:15 AM
Autoworks's Avatar
Default Re: MY CRX should be running sooon!! (CRX_1.8T)
Thanks, found a caliper this morning.
Has anyone else noticed that after installing the Integra hubs the turning radius gets alot bigger (wheels turn alot deeper) in the front??
Also, fo ranyone that was wondering, with the N1 pulley you do definately need the 92 Acura Vigor power steering pump belt.
Old Apr 13, 2005 | 04:07 PM
Autoworks's Avatar
Well, ended up buying two calipers (might as well make it all brand new), breaks look good, they fill up the 14" wheel. But I'm pretty much at a stopping point until my Hasport subharness gets here on Fri, along with my Pressure Plate Bolts from Honda ($5 each )
Old Apr 20, 2005 | 04:56 PM
Autoworks's Avatar
Well, I finally was able to crank my car today WOOHOO. Completely dead for 3 years, and it finally woke up.
I only let it idle for a few minutes, no leaks, idles smooth at about 1k, due to intake mani/tb combo. Sad part is I bought a dead *** PR3 for it off ebay. It wouldn't crank, I borrowed another guys PR3 and it crunk right up, so I'll be using his. I'll probably just swap to OBDI now.
Also, I have to cut my crossmember tomorrow to connect the seconf half of my header, she should be driveable hopefully tomorrow-straight to the muffler shop
Props to the crew I have dropping the motor
Old Apr 20, 2005 | 05:02 PM
CRX_1.8T's Avatar
Congrats man! Glad to see you got her breathing again!
Old Apr 21, 2005 | 04:53 AM
Autoworks's Avatar
Thanks, crossing my fingers, everything should be done today, and I'll take it for a test drive
97SS
Apr 6, 2007 07:13 PM
c jackson
24
Jan 23, 2006 09:35 PM
OreoEF8
May 15, 2003 12:53 PM
hybrider
Jun 19, 2002 12:37 PM
