Fuel pump location.
Old Apr 12, 2005 | 05:39 PM
gsrswapdcivic's Avatar
Default Fuel pump location.
yes i know where the fuel pump actually is, yes i know you SHOULD drop the tank.
The question i have is has anyone ever cut the floor board out so you dont have to drop the tank? and will the lines let you pull the pump out?
i have the spot( I think) and i just wanted to see some pics of the work some one else has done so i can elaborate or copy. im lazy and dont wanna drop the tank.
oh and i have carpet so no i dont care to have a hole in the floor and know i will not leave it open i have an aluminium peice to cover it
PICS if you have them would be great.
Old Apr 12, 2005 | 06:02 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Fuel pump location. (gsrswapdcivic)
Please,Just do the job right....
To get the pump assembly out would take a fairly large hole
which would weaken the structure of a car
that is not that strong to begin with...
Old Apr 12, 2005 | 06:05 PM
whole9's Avatar
Default Re: Fuel pump location. (88DXCRX)
The hardest part about dropping the tank for me was emptying the gas, be carefull now =]
Old Apr 12, 2005 | 06:09 PM
BlueShadow's Avatar
If it's your first time working on the fuel pump you might wanna just drop the tank to make sure there is nothing beneath the cutting area. You dont wanna cut your hole and accidentally cut a fuel line or something.
Old Apr 12, 2005 | 06:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Please,Just do the job right....
that is not that strong to begin with... </TD></TR></TABLE>
**** man your right im glad some one said that before i fucked up my car i just wasnt thinking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">The hardest part about dropping the tank for me was emptying the gas, be carefull now =]</TD></TR></TABLE>
Im not sure if you have the same tank i have but their is a plug in the bottom of mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">If it's your first time working on the fuel pump you might wanna just drop the tank to make sure there is nothing beneath the cutting area. You dont wanna cut your hole and accidentally cut a fuel line or something.</TD></TR></TABLE>
its not the first time i have had to take the tank out it was justa big deal i guess
Old Apr 12, 2005 | 07:04 PM
93formula's Avatar
what you could do is, after you take it out and you know where it is you can cut a hole for the next time and weld in a access door.
thats what i did on my formula, but i didnt drop the tank in the first place. on the f bodies its a common mod and exact measurements were posted on the internet on where to cut.
access doors make life a lot easier, not sure about the EFs but on the f bodies, you have to drop the rear axle, exhaust, and drive shaft just to drop the tank.
Old Apr 13, 2005 | 06:13 PM
i looked at the tank out of the car and i would have to cut a huge square out and then cut a channel for the hard line to get the pump out it would look like ****!
i did it to a shell so i know what it would look like.
Old Apr 13, 2005 | 07:01 PM
golfcart's Avatar
Thats a pretty serious thing to be messing around with man. I'd just break down and do it the regular way otherwise you may just be asking for more problems and more work than originally planned afterall.
GoLowDrew
Jun 10, 2013 01:37 PM
A-dub5513
Apr 15, 2010 04:28 PM
sbarmann
Mar 7, 2006 11:46 PM
DaveF
Oct 20, 2005 09:16 AM
trooper0641
Jul 13, 2005 08:21 PM
