I need help???? anyone, b16 trouble
I just put a b16a in my 89 dx hatch and I have no spark, no fuel, but it does crank. can anyone tell me if I need an injector resister box? or what I do need cause I'm at the end of my rope.
From: I told you to wait in the truck in Texas, United States
Assuming the wiring is correct and in the MPFI configuration,
No spark,no fuel would probably be a bad distributor or ecu..
Or maybe a broken timing belt..
The distributor signals the ECU which controls fire and fuel..
If the cam belt breaks the distributor won't turn thus no signal..
When you turn the key on,does the check engine light come on then go out?
If not check fuse #14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx »</TD></TR><TR><TD CLASS="quote">yes, you do need the resistor box. you need to convert it to mpfi. you will need to add wires to your ecu</TD></TR></TABLE>
You did convert it to MPFI didn't you?
If not,look for links posted in the FAQ section:
https://honda-tech.com/zerothread?id=637661
I just got a new distributor from distributor king, so it could be ecu or timing belt you say. So I don't need and injector restistor box?
so I need to convert to mpfi even though I'm swapping the whole motor? and I need an injector resistor box and to add some wires to the ecu, what wires and where, can anyone tell me step by step??
The link I posted above is for the FAQ section..
Go there,look for my avatar..READ what I posted and click the the links
Besides what comes on the B16,
You will need injector clips, a resistor box and it wiring...
drsessum
Jun 14, 2009 11:26 PM
akteamster
13
Jun 17, 2006 07:47 AM
