help! my windows wont work. NOT fuse.
Old Apr 12, 2005 | 03:58 PM
deconstruct's Avatar
Default help! my windows wont work. NOT fuse.
my del sols passenger and rear windows wont roll up. i took off my roof and rolled windows down. when i went to roll them up they wouldnt work. driver side window still works. i checked the fuses and they are fine. what do i do?
Old Apr 12, 2005 | 06:15 PM
Cuong-nutz's Avatar
Default Re: help! my windows wont work. NOT fuse. (deconstruct)
perhaps faulty connection? contacts are dirty on switch? can you roll it up on the passenger side switch?
Old Apr 12, 2005 | 07:08 PM
Default Re: help! my windows wont work. NOT fuse. (Cuong-nutz)
No, I cant roll it up on the passenger side.
Old Apr 12, 2005 | 07:10 PM
CivicrtypeTOO's Avatar
its a wiring problem. hmm...let me think
Old Apr 12, 2005 | 07:25 PM
Cuong-nutz's Avatar
Let me clarify this. They only can roll down but won't roll back up? Or when you rolled them down, they stopped working period? I can't remember exactly the correct wiring schematics from civics to del sol models, but IIRC, if the main switch isn't connected (the one on the driver side door panel), the passenger window will fail to roll up. My guess is that the contacts are poor on the switch. Try wiggling the plug to the switch while trying to roll the windows up. If that's not the case, see if you're getting any power to the passenger and rear window and start from there. Does the auto down on the driver side work?
Old Apr 12, 2005 | 08:43 PM
they got stuck in the down position. the driver side works perfectly. the driver side plugs are connected, i even unplugged it and wiggled it around. tomorrow im gonna check to see if they are getting power.
girliehonda
Honda Civic (2001 - 2005)
10
Oct 16, 2016 03:32 PM
MikesEJ1
Jun 2, 2012 07:12 PM
kryptekz
Aug 21, 2011 01:26 PM
del_sol 2009
11
Apr 21, 2009 01:55 PM
Xerxes3333
Mar 10, 2004 06:56 PM
