k20 in a dc2 (hard?)
Old Apr 12, 2005 | 03:27 PM
Spoogen_1's Avatar
Default k20 in a dc2 (hard?)
Ive seen a k20 in a teg. i wanted to know how hard it is to do, with a full swap, with axel and everything. Is there any special fab. i have to do ??
Old Apr 12, 2005 | 03:30 PM
JamaicanDM's Avatar
Default Re: k20 in a dc2 (Nexus131)
just type k20 in the search menu and there is alot of info about the sawp, what u need, and where to get em from
Old Apr 12, 2005 | 04:34 PM
Goatsterrman's Avatar
Default Re: k20 in a dc2 (JamaicanDM)
Almost identical to doing it in an EG. Not tough at all.
Old Apr 13, 2005 | 07:58 AM
Spoogen_1's Avatar
Default Re: k20 in a dc2 (Goatsterrman)
What kinda fabrication do you have to do, or is it a pretty simple swap??
Old Apr 13, 2005 | 08:20 AM
JDMotive's Avatar
No fabrication really...unless you plan to make your own mounts.
Only have to drill out the spot welds on the pass. side frame rail bracket and remove it...than cut hole in the floor/firewall for the shifter cables.
THe engine goes in really smooth with the Hasport mounts.
Old Apr 13, 2005 | 08:53 AM
Default Re: k20 in a dc2 (JDMotive)
http://www.hybrid-racing.com/a...l.pdf
Just to give you an idea, here are the instructions using the Hybrid-Racing kit.
Old Apr 19, 2005 | 05:26 PM
NAturalDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">No fabrication really...unless you plan to make your own mounts.
THe engine goes in really smooth with the Hasport mounts.</TD></TR></TABLE>
after you remove the tranny mount dont you have to drill 2 holes for the new mounts? cause if you look at the mount in place thats what i see
Old Apr 19, 2005 | 05:34 PM
NAturalDC2's Avatar
Default Re: k20 in a dc2 (NAturalDC2)
NM i just read the hybrid install article haha
Old Apr 19, 2005 | 06:49 PM
G U E C O's Avatar
the hardest thing in the wiring, but i think you can buy the wire harness that is plug and play for 350
Old Apr 20, 2005 | 12:36 PM
Default Re: (stock93cx)
That is the install guide for the EG Harness Install. Most people finish with 20 minutes. Version 1.2 should be up shortly making the install slightly easier.
Yes, the harness is available for $350.00
Old Apr 20, 2005 | 04:04 PM
kmar111's Avatar
Default Re: (Goatsterrman)
You must be talking about me , i live in P. Pines also , here is the tread on my car i post alittle while back if you need any help or any question let me know!
https://honda-tech.com/zerothread?id=1093501
When did you see my car???? if it is me your talking about!
Old Apr 20, 2005 | 04:51 PM
Spoogen_1's Avatar
Default Re: (kmar111)
Oh snap dude it is you. I met oyu once when people use to meet up at Sunoco. I have a green LS
Old Apr 20, 2005 | 04:57 PM
kmar111's Avatar
Default Re: (Nexus131)
yeah i dont really remember you, you need to be alittle more specfic there are tons of green ls! , but if you decide to do teh swap , let me know ill help you out.
Old Apr 20, 2005 | 05:02 PM
Spoogen_1's Avatar
At the time it only had exhaust so you probly dont know, but i have a few threads with pic of my car. Anyway i rember you car cuz of the motor. You did alot more since then. Like the cf hatch. I still want one. ANyway how hard was it for you to do the swap and have you had any problem are anything?
Old Apr 20, 2005 | 05:31 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kmar111 &raquo;</TD></TR><TR><TD CLASS="quote">You must be talking about me , i live in P. Pines also , here is the tread on my car i post alittle while back if you need any help or any question let me know!
When did you see my car???? if it is me your talking about! </TD></TR></TABLE>
That car is fugg'n bang'n
There is another red RS on here with a k20 swap too.
Old Oct 2, 2005 | 10:11 AM
HomeDepotMade's Avatar
Default Re: (skunked)
what numbers are u hitting at teh 1/4 track? Man i wonder what kind of power and feel you get out of a k10 engine in a teg.
phoQ
Oct 26, 2008 06:00 PM
soulimports
Oct 3, 2008 07:58 PM
packman
May 8, 2006 06:30 PM
ADVAN JDM
Apr 20, 2004 10:26 AM
GreenR
Nov 28, 2003 12:40 AM
