Best Setup For Good Reliable Midrange Power...
I'll give the inevitable JRSC option. Great low and mid range power, it's like a completely different car. I can be cruising in fifth gear at 75mph and just punch it with no downshift. 100mph is only seconds away.
The downside? It's hard to tune right, expensive, needs a lot of additional parts (some of which aren't cheap), and doesn't make the top end power as advertised.
budget setup:
AEM shortram intake, JDM ITR 4-1 header, carsound cat, apexi ws exhaust, aem cam gears, port flow titanium retainers, portflow springs
screw the budget and do it right set up
AEM CAI, ported TB & intake manifold, SMSP header, carsound 2.5in cat, smsp exhaust, Jun type 2 cams + cam gears, Jun valvetrain, bore ITR block to 84mm & GE sleeves with Endyn pistons, eagle rods
[Modified by B18cKiller, 1:30 AM 1/30/2002]
the AEM is *** for low/mid-range power...ever seen a dyno plot of one?
The best intake system for mid-range is a Comptech Icebox.
the mugen airbox is good for mid-range..i sat in a friends car when he installed it. noticable difference.
Also, someone recommended Spoon cams..its a good recommendation. Spoon cams offer loads of mid range power..i gained substantially on my f/i setup..and i have seen dynoplots of ppl with spoon cams compared to stock.
, Dont forget I mentioned SPOON cams also.(click on link under sig. and than on dyno tests, check under acura
)[Modified by ITR#132, 10:06 PM 1/29/2002]
I`m happy with drop in filter, 421 header, bigger t/b and crower stage 2 cams..(street/ralley)
Still untuned but noticible harder pull between 4000 and 6000 rpm.
Drinker
[/edit]
