A day at HOOKUPS...
Old Apr 12, 2005 | 12:50 PM
thevanitygroup's Avatar
Default A day at HOOKUPS...
Went in today to tune my car which has been running horrible for a little while now because of some changes ive made and things ive neglected. My car is being horribly choked by my exhasut and header along with the fact that we beleave the cat is clogged from running rich for so long etc... Here's some pics and a video of one of the runs. The numbers basically terrible because of the mentioned problems but nothing that cant be fixed with a little $$$... Chris did an great job pulling some power out the mid range in a stingeeeee motor . Changing the header, cat, exhaust and ecu shortly then will be back to tune.
The engine is a basically stock CTR setup.
P2T OBD-II ECU did'nt let us take it passed 8200
145 HP / 100 TQ
DYNO VIDEO
http://www.jwalt.com/tvg_images/aarons_dyno.MOV
Modified by thevanitygroup at 2:51 PM 4/12/2005
Old Apr 12, 2005 | 12:54 PM
Combustion Contraption's Avatar
I wanna see the vid, but its not workin for me.
Old Apr 12, 2005 | 01:09 PM
Default Re: (LsVtec92Hatch)
It's in Quicktime format so if you dont have it, you may need to download it: http://www.quicktime.com
Old Apr 12, 2005 | 01:23 PM
itralex's Avatar
Default Re: (thevanitygroup)
i have quicktime...and yeah, the vid isn't working
Old Apr 12, 2005 | 01:30 PM
Default Re: (itralex)
Link fixed...
Old Apr 12, 2005 | 01:41 PM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevanitygroup &raquo;</TD></TR><TR><TD CLASS="quote">Link fixed... </TD></TR></TABLE>
Not for me
Old Apr 12, 2005 | 01:52 PM
Default Re: (Fat Bradstard)
Ok so now it's REALLY fixed.
Old Apr 12, 2005 | 02:26 PM
flesh199's Avatar
it work here
Old Apr 12, 2005 | 02:39 PM
Got it to work here now! It does sound like it wants to rev quite a bit higher...
Old Apr 12, 2005 | 03:43 PM
Yep. It will make power to 9k. The ECU just wont let it. Hopefully now that I know where my problem spots are, I can pin point them and eliminate the bottle necks. This motor has alot of power left in it.
Old Apr 12, 2005 | 10:39 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">i have quicktime...and yeah, the vid isn't working</TD></TR></TABLE>
RIGHT CLICK, SAVE AS..then play it after you save it on your comp.
Old Apr 13, 2005 | 05:25 AM
137's Avatar
137
Default Re: (EVOL)
id worry about making power through the power band instead of worrying what rpm you can shift at imo.
Old Apr 13, 2005 | 06:02 AM
rodimus's Avatar
Default Re: (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">id worry about making power through the power band instead of worrying what rpm you can shift at imo. </TD></TR></TABLE>
true but a ctr setup is geared towards making power up there...it's a shame if you can't even rev that high.
Old Apr 13, 2005 | 08:04 AM
Default Re: (EVOL)
The power band is ultra smooth and it makes great power in the mid range. Like EVOL said though, I would still be making great power passed 8200.
Old Apr 13, 2005 | 08:07 AM
Toxidomask's Avatar
how much for dyno test at hookups?
Old Apr 13, 2005 | 09:00 AM
{Powered by VIII}'s Avatar
Default Re: (Toxidomask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toxidomask &raquo;</TD></TR><TR><TD CLASS="quote">how much for dyno test at hookups?</TD></TR></TABLE>
i would like to know as well!!
Old Apr 13, 2005 | 09:47 AM
Default Re: ({Powered by R})
PM Chris "HOOKUPS" is his user name. He can give you a more direct price. I would expect it to be no less then $100+ per hour. Usually a simple tune (Fuel, Cams, Timing) should take no more then 1 hour. Chris had my car tuned in farely quick. You can call and make an appointment, he can usually sqeeze people in. The numbers in my signature, tell him Aaron sent you
Modified by thevanitygroup at 11:20 AM 4/13/2005
Old Apr 20, 2005 | 04:44 PM
Toxidomask's Avatar
thanx, ill do this when i get my motor running.!!
collie1988
Engine Management and Tuning
Apr 28, 2011 02:57 PM
Chiller
May 19, 2004 04:51 PM
boszyen
May 3, 2004 03:12 AM
builtprelude
May 2, 2004 10:32 AM
Pistonhead
Jul 1, 2001 12:02 AM
