For some odd reason...
Old Jan 29, 2002 | 12:52 PM
EL Vap133's Avatar
Default For some odd reason...
Ever since I slapped the B16A in my 88 CRX DX and lowered the car at the same time, my alignment isn't the same. I had the car aligned and it was great for a while and then it went back to it's bad alignment. Anyone else have this problem? Anyone have any suggestions on how to fix this problem? Could the shop have done something wrong? Thanks.
P.S. It pulls to the right and I have to have my steering wheel at 9 o'clock...
[Modified by Vap133, 9:53 PM 1/29/2002]
Old Jan 29, 2002 | 01:39 PM
sgT's Avatar
sgT
Default Re: For some odd reason... (Vap133)
check your tire pressure
check your wheel bearings
check for any worn suspension bushings
Old Jan 29, 2002 | 04:12 PM
EL Vap133's Avatar
Default Re: For some odd reason... (sgT)
I'll check that out , thanks.
Old Jan 29, 2002 | 05:46 PM
Jared's Avatar
those 88-91s have a bad problem with wearing the upper ball joint after they get a few miles on them. check it, as well as your tie rod ends and lower ball joint.
Old Jan 30, 2002 | 09:44 AM
EL Vap133's Avatar
Default Re: For some odd reason... (Jared)
I'll keep that in mind, thanks!
Old Jan 30, 2002 | 11:00 AM
speedillusion's Avatar
New User
is your car bouncy at times? time for a new set of shocks...
me too.
Old Jan 30, 2002 | 12:40 PM
EL Vap133's Avatar
Default Re: For some odd reason... (midnitekreeper)
It wasn't until I lowered it and slapped the B16A but not that much, it only bounces a little bit. Do you think I should replace the shocks? Thanks.
Old Jan 30, 2002 | 03:19 PM
New User
are you running on stock struts or shocks?...
what year is this car?...
if it's been a while, say, 6 to 8 years... yup, then it should be about time
Old Jan 30, 2002 | 04:19 PM
EL Vap133's Avatar
Still using the stock struts/shocks, the CRX is an 88 and it's lowered on Skunk2 coilovers.
Old Jan 31, 2002 | 11:04 AM
wreckedagain's Avatar
Yeah i would definitely replace them, it will probably be like a whole new car.
Old Jan 31, 2002 | 11:42 AM
EL Vap133's Avatar
Default Re: For some odd reason... (wreckedagain)
Ok guys, I will replace them with the KYB adjustable shocks/struts, thanks.
Old Jan 31, 2002 | 01:52 PM
New User
i need some also. if you get a good buy, please lend a hand.
thanx
Old Jan 31, 2002 | 03:07 PM
EL Vap133's Avatar
For what kinda car? I'm pretty sure I can get some at a good price.
Old Feb 1, 2002 | 11:54 AM
New User
i'm from daygo. if u can find me a good buy on the net, that'd be ok.
it's for a '96 civichb... dx.
it'd be great if i can get the koni yellows.
thanx
CarolinaHonda
Sep 3, 2011 08:41 PM
dpacheco
Suspension & Brakes
Nov 1, 2010 01:52 AM
shawnrg2881
May 10, 2008 03:17 AM
joseph87
Mar 30, 2008 07:15 PM
dpkelly
Jan 30, 2006 08:41 AM
