Buddy club stage 4 users.........Are you running a Stock or Aftermarket Timing Belt?
Its just a hard decision to choose from. Ive heard both ends and ive seen both stock and aftermarket belts break on 200+ NA motors. I just want to do this right the first time. I want to hear feedback from "only" Buddy club stage 4 users.
Tbone?
Tbone?
I used stock T-Belt with Toda Spec C cams. THey have very similar big lobe lift and small lobe lift and duration. No problems at all. Just don't over or under tension.
But's you have to call a horse a horse. :-)
There would be no need for stressing valve springs if it were not for stressing cams. I think breaking timing belts have more to do with user install error than anything. But if I had to blame it on something mechanical I would blame it on ramp speed/angle of the cam.
the way i tighten a belt is that i get a coat hanger and bend it into a hook so i can grab the tensioner and pull the tensioner till the belt is tight then i tighten the tensioner.
Its always worked for me the easiest and no problems. Done it to several motors.
Toda b's stock belt 1 Tbone 0 bent all 16
Every other cam I have run(at least 5 others) on same PE belt
it has stretched some though..
nEoMuGen
Jan 10, 2004 02:24 PM
JSIR
May 10, 2002 07:54 PM
