Plasma cutter slag (manifold cutting)
Old Apr 12, 2005 | 10:39 AM
jon volk's Avatar
Default Plasma cutter slag (manifold cutting)
Lately Ive been using the plasma cutter to blow the hole needed for the turbo flange in log manifolds. The only downside to this has been the slag that sticks to the inside of the manifold. Ive been spraying the inside with anti-spatter spray you typically use for MIGing to keep the little BB's off stuff but it burns off fairly quickly. It helps out quite a bit but I wanted to know if anyone else had a better solution to keeping the slag from sticking inside the manifolds.
Old Apr 12, 2005 | 12:18 PM
L-CON1's Avatar
Default Re: Plasma cutter slag (k20 jon)
nozzle dip?
gehlSRT
Welding / Fabrication
Oct 11, 2011 09:34 AM
eg2phosizzle
11
Jan 24, 2006 09:37 AM
lkailburn
Jul 31, 2005 11:57 AM
TurBoXBirD16
May 7, 2003 01:20 PM
J2turbo21
Dec 26, 2002 06:24 PM
